subaru ej20 wrx thread question
split_trix
PostPosted: Thu May 18, 2006 3:54 pm    Post subject: subaru ej20 wrx thread question Reply with quote
hi, im trying to put the engine on a stand and was wondering what thread the studs are that locate int he gearbox bell housing...... its not M10 cos i've tried those.... do the japs use imperial threads ?
cheers
chris
52 vwrx
PostPosted: Fri May 19, 2006 8:22 am    Post subject: Reply with quote
ah yes that problem!! Not much help im afraid but they are metirc just with an odd pitch which I cant remember - try mailing RJES he will be able to give you detials- i ended up down the scrappy robbing bolts from legacies.
ricola
PostPosted: Fri May 19, 2006 9:22 am    Post subject: Reply with quote
They are an M10 metric fine, off the top of my head I think that is M10x1.25..
I'm trying to source some of these countersunk as when I'm reversing the rear cradle the bolt heads hit it. If anyone knows a source I'd love to know! In the mean time I have some button head bolts which I will cut down and slightly countersink..
Rich
starspider
PostPosted: Wed Jun 14, 2006 3:16 pm    Post subject: Reply with quote
The thread is M10x 1 got mine from the local motorbike shop
doppelganger
PostPosted: Wed Jun 14, 2006 7:26 pm    Post subject: Reply with quote
wrong,ricola is right Grin the m10x1 is flywheel bolts i believe Wink
vwdrc class rep
PostPosted: Sat Jul 29, 2006 3:24 am    Post subject: Reply with quote
The thread is M10 x 1.25. This is not the same as ISO Metric fine (M10 x x1.0), as used all over Europe. It's Japanese spec M10. The Japs use only one pitch M10 for both applications, where here we use M10 x 1.5 for structural bolts, and M10 x 1.0 (M10 fine) for pipe gittings such as brake linesm etc.
It can be difficult to get hold of M10 x 1.25 here. Your best bet is to get 'em from scrap Japanese products. Also be aware that if you do get new European M10 x 1,25 here, it will almost certainly have the ISO 17mm hex head. The Japs use a 14mm hex flange bolt / nut as standard, abd this can have an effect on clearance for tools.
Hope that helps
ricola
PostPosted: Sat Jul 29, 2006 7:32 pm    Post subject: Reply with quote
Myself and a friend ended up ordering a small batch of screws for the lower two adapter plate bolts. They are M10x1.25 with a countersunk head, grade 10.9. Just need to countersink the adapter plate and no more hassles with transmission bushing clearance!
We have a few left over (minimum batch sizes!) so if anybody wants some give me a shout..
Rich
autohausdolby
PostPosted: Tue Aug 08, 2006 10:24 am    Post subject: Reply with quote
I wondered why I couldn't get anything to go in there!
www.autohausdolby.co.uk
VWSP85
