alternator probs
evercold
PostPosted: Thu Aug 02, 2007 6:29 pm    Post subject: alternator probs Reply with quote
hello everyone,my battery wasnt charging checked my alternator and it was pushing out 10v ,so i brought a new one just put it one and its doing the same only 10v , i havent got my alternator light connected(wasnt one on the vdub engine) would this cause this. if not any one got any clues.
thanks
ricola
PostPosted: Thu Aug 02, 2007 9:46 pm    Post subject: Reply with quote
Some alternators have to have the charge light hooked up to allow charging, definitely sounds like that's the case!
Rich
PostPosted: Thu Aug 02, 2007 10:02 pm    Post subject: Reply with quote
Fully charge your battery first, around 13V before doing anything else.
Check earth straps:
1/ Gear box to chassis
2/ Battery earth to chassis
3/ Engine to battery earth (I really must do this!)
Do you mean "Brand spanking new"? If so it sounds like you're not getting enough excitation voltage.
This looks like it's a pretty good read:
http://www.forparts.com/ICsubaruelectricalsystem11.05.htm
Not having a charge light is a BadThing(TM) especially on a dub! (Light comes on and it could have told you your alt belt had snapped and you've lost all cooling)
They're easy enough to wire up - do it. It's two wires and a bulb - POP.
No, not having one wouldn't cause this problem.
PostPosted: Fri Aug 03, 2007 9:24 am    Post subject: Reply with quote
Yer I have had the same proble, and It was because the alternator would not charge properly with out thr alternator light being connected.
evercold
PostPosted: Fri Aug 03, 2007 11:06 am    Post subject: Reply with quote
thnaks peps iv been told that the bottom left terminal on the alternator is the charge light is this right, my batterys dead so i will give that a charge and check my earths, what light on the dash is the alternator is it the "G" red light.
thanks matt
ps. elusive year brand spanking new
PostPosted: Fri Aug 03, 2007 12:53 pm    Post subject: Reply with quote
JP, Ricola - thanks for that guys, live and learn
Evercold, sorry for the duff gen.
evercold
PostPosted: Fri Aug 03, 2007 3:26 pm    Post subject: Reply with quote
just to let you know you need you alternator light connected for your alternator to work,any one want a new alternator for a ej 22 Grin
thaks peps you make this a whole lot easyer
evercold
