bits wanted
lowlight 185
PostPosted: Wed Feb 20, 2008 7:21 pm    Post subject: bits wanted Reply with quote
hi folks getting some bits together to start conversion 2.2 scooby
1.flywheel
2.starter
3.bolts
4.clutch
5.fuel pump
6.throttle inverter
7.the bit that stops your cam belt jumpiing off
thats all i can think of for now thanks Happy
Sutton in Ashfield .Nottinghamshire
home of the robin hoodys
PostPosted: Wed Feb 20, 2008 7:41 pm    Post subject: Re: bits wanted Reply with quote
1.flywheel - breakers or Doppleganger
2.starter - ditto
3.bolts - which bolts? Scooby main dealer, £1.50 or so each for bellhouse ones
4.clutch - friction plate? 228mm Type 4 one if using RJ Bell house
5.fuel pump - External? mine's Bosch (was fitted to a Jag) any high pressur petrol FI pump will prolly do. £15 from a breakers
6.throttle inverter - Custom Off Road (Australia, great service!), RJES or Turbo Thomas
7.the bit that stops your cam belt jumpiing off - Cover? (I noticed yours was cracked on the LHS)
Answers in line
Add in a new Scooby release bearing.
lowlight 185
PostPosted: Wed Feb 20, 2008 7:50 pm    Post subject: Reply with quote
the bit that stops cam belt coming off is a giude that didnt come on automatics thanks Happy
PostPosted: Wed Feb 20, 2008 11:22 pm    Post subject: Reply with quote
Can you post a picture? I've only seen manual engines
Ta
lowlight 185
PostPosted: Thu Feb 21, 2008 4:59 pm    Post subject: Reply with quote
http://www.rjes.com/html/engine_auto_to_manual.html
does this help ime crap with computers Happy
PostPosted: Thu Feb 21, 2008 7:29 pm    Post subject: Reply with quote
Ahh, gotcha.
You'll waste lots of time at a breakers removing that.
Errrm, I'm gonna state the obvious (like what Rich said) Subaru dealer. You'll find some new parts are very reasonably priced!
