rjes Jedi Guardian
Posted: Fri Feb 22, 2008 12:15 am Post subject: |
Thanks for the info. Mine is also totally bolt on for RHD, and requires only very minor plastic trim modifications for LHD. If theirs is electro hydraulic, then what I'm working on will still have a number of unique selling points.....
Should have a speed sensitive assistance version up and running soon. Testing has shown that while not essential, this will make it very much better. _________________ Regards,
www.rjes.com |
smartdriver Padawan
Posted: Sat Feb 23, 2008 12:59 pm Post subject: |
That's the spirit
Paul _________________ convertin' a VW T2 t1 '69 15 window "splitty" into a daily driver, to be continued....... |
Posted: Mon Mar 17, 2008 4:33 pm Post subject: |
hi chaps...im back with some progress...and its good news whether your combining a rack and EPAS column like me or a VW box and column as both use the same rubber donut set up.
i finally mounted the rack with some proper braketry - the key to getting equal lock is to get the link arm at 90 degrees to the idler....lots of measuring and thinking and then i made some proper brakets and mounted the rack (obviously irrelevant if your using the OG steering box)
now i could turn attention to the link: The corsa colum uses a short splined link with a UJ on either end (available on ebay for a few quid if you dont have one). i discovered the spline allows it to be easily seperated into two parts - male and female. This is the female part - the part that needs modifying:
The VW and rascal both use a rubber donut....the original colums mount onto this with a simple plate and two bolts.....so i trimmed the bottom of the bottom UJ and welded on a plate drilled with holes to mount to the rubber donut. i welded this inside and out. If your not a confident welder get this done professionally - you really dont want it to shear.
To prevent damage to the UJ you have to do short blasts and then Cool it in water or the heat will seize the UJ. The end result is as above - a UJ with a bolted plate on the bottom.
All pretty easy?? well it gets easier. Vauxhall kindly designed the male and female splines so they slide up and down giving about 4 inches of adjustment . So when I rejoined the female with the male half of the link all i had to do was connect the top half to the corsa EPS rack and then tap the female section down the male until it engaged with the Rack spline. Bolt it up...job done.
view from below - all linked up:
All i need now is a control module to fire it all up. Ill keep you posted on that one I have a plan. |
Fatboy Wannabe
Joined: 17 Jan 2007 Posts: 5 Location: Stourport on severn
Posted: Mon Mar 17, 2008 10:31 pm Post subject: corsa column |
rjes-count me in for one of your kits asap!!!!
Dodgy wrists after a bike accident and this is the one thing that spoils my van! Well that and AAZ lumps that keep on giving up the ghost on me!!!
What sort of price would we be looking at for the basic system without speed sensors? |
mat* Wannabe
Posted: Mon May 26, 2008 9:44 am Post subject: |
has the kits you done worked well  |
justin pane Force Sensitive
Joined: 14 May 2008 Posts: 19 Location: SOLIHULL W. MIDS
Posted: Wed Aug 20, 2008 5:32 pm Post subject: power steering |
| Can anyone help with electric connections to the ECU, its a corsa unit Ive fitted to my 72 bay van, from the ECU there are 5 fine gauge wires that connect to the control module and 2 heavy gauge wires (red and brown), where do these 2 wires go ? |
_666_ Force Sensitive
Joined: 26 Jul 2009 Posts: 16 Location: South Australia
Posted: Sun Jul 26, 2009 6:45 am Post subject: |
hi rich,
do you have any completed pics of the unit ? ..specifically how you mounted it ?
also what did you do about the VW Ignition, and VW Stalks? |
claw_finger Force Sensitive
Joined: 21 Oct 2007 Posts: 12 Location: deaf, dumb & blind
Posted: Sat Aug 01, 2009 10:07 am Post subject: |
I have a corsa c rack, can anyone recomend where to buy the adjuster box
it' going in a T3 |
Posted: Sun Aug 02, 2009 1:25 pm Post subject: |
yeah i did see it but the way i understood what he said was that the pics are only the temperary brackets,
naturally i wouldnt mind not knowing how it was done, but my kombi is my daily driver so i cant pull it appart to try and fit the column in.. i need to know what i need to go it, and do it all at once..  |
Posted: Mon Aug 03, 2009 11:42 am Post subject: |
666- not much has changed from the above pics - the framework is still a temporary set up but it will just be refined and properly welded to make it final. As JP says i will use Corsa stalks and subaru ignition module...you dont HAVE to do this though.
I have just rememebred that you want more pics of the rack mounting etc - i will try to do this tonight! |
Posted: Tue Aug 04, 2009 1:41 am Post subject: |
| awsome, and yeah id preffer to use the corsa stalks myself anyway, out with the old and in with the new haha, it would go well with my Toyota V8 Engine :P |
