can youu turn exhaust manifolds around 180 degrees
pantswagen
PostPosted: Thu May 29, 2008 4:36 pm    Post subject: can youu turn exhaust manifolds around 180 degrees Reply with quote
ie looking at the back of a van
-have this pointing back on the right
-instead of forward on the right
ie symetric or offst?
PostPosted: Tue Jun 03, 2008 5:46 pm    Post subject: Reply with quote
the manifold flanges on the heads are symmetrical, however, whether you can turn the header around depends on whether the header you have has enough room to clear everything (mainly the oil filter, cam belt covers, etc). Someone on here has used a turbo header on a n/a engine, fitted in reverse, with a single silencer under the rh end of the bumper. It looked quite neat.
Some of the standard Subaru headers fit in reverse too.
