New Products ?
cali red
PostPosted: Sun Jul 06, 2008 11:23 am    Post subject: New Products ? Reply with quote
Will RJES be using this forum to inform us of new products for sale ?
PostPosted: Mon Jul 07, 2008 4:30 pm    Post subject: Reply with quote
Yes. I have Subaru splined input shafts now, but they won't be on the site untill they're tested by Mr Doppelganger.
The fixture for bus exhausts is just about finished, and I need to order the first batch, which I will probably be doing in the next week or two.
MostlyMonki
PostPosted: Tue Jul 08, 2008 3:29 pm    Post subject: Reply with quote
might be interested in an input shaft when theyre for sale Richard. let me know when Happy
PostPosted: Tue Jul 08, 2008 5:54 pm    Post subject: Reply with quote
sti clutch and flywheel should be in this week with new shaft so it will be in use at bugjam Happy
MostlyMonki
PostPosted: Tue Jul 15, 2008 12:59 pm    Post subject: Reply with quote
how much of a job is it to change the shaft? any idea what it would cost to get done?
PostPosted: Tue Jul 15, 2008 3:42 pm    Post subject: Reply with quote
you CAN do it yourself ,i did Laugh Out Loud
MostlyMonki
PostPosted: Tue Jul 15, 2008 5:15 pm    Post subject: Reply with quote
exactly what i wanted to hear! Cool
PostPosted: Tue Jul 15, 2008 10:50 pm    Post subject: Reply with quote
This is what you wanted to see:
http://www.vwkd.co.uk/bb/viewtopic.php?t=840
Now go do it Happy
PostPosted: Wed Jul 16, 2008 8:39 pm    Post subject: Reply with quote
Cheers Elusive - I didn't know that was there. The basic arrangement is the same on a bus box, excepy you unbolt the bell housing rather than the side plate to gain access to the circlip on the input shaft.
The job is easily DIYable to anyone who maintains their own VW. The most complex it'll get is if you have a diff which is too big a diameter to allow the sleeve to slide far enough along the input shaft. It so, you'l have to slacken the diff side bearing adjusters to allow the diff to move out of the way. Be sure to scribe a mark on them, and count how many turns you unwound them by. As long as you do, you'll easily be able to set the diff up in exactly the same place as it originally was.
The Beetle 'box ring and pinion look like scale models when you're used to seeing bus ones!
PostPosted: Wed Jul 16, 2008 10:19 pm    Post subject: Reply with quote
While you're here Rich... who makes a nice circlip removal tool for those style circlips (read "feckingcnutbo11oxbstard, sh1tbag", not the nce ones with little holes) ones?
