Electric Power steering (EPS)
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Feb 22, 2008 12:15 am    Post subject: Reply with quote
Thanks for the info. Mine is also totally bolt on for RHD, and requires only very minor plastic trim modifications for LHD. If theirs is electro hydraulic, then what I'm working on will still have a number of unique selling points.....
Should have a speed sensitive assistance version up and running soon. Testing has shown that while not essential, this will make it very much better.
smartdriver
PostPosted: Sat Feb 23, 2008 12:59 pm    Post subject: Reply with quote
That's the spirit
Paul
convertin' a VW T2 t1 '69 15 window "splitty" into a daily driver, to be continued.......
PostPosted: Mon Mar 17, 2008 4:33 pm    Post subject: Reply with quote
hi chaps...im back with some progress...and its good news whether your combining a rack and EPAS column like me or a VW box and column as both use the same rubber donut set up.
i finally mounted the rack with some proper braketry - the key to getting equal lock is to get the link arm at 90 degrees to the idler....lots of measuring and thinking and then i made some proper brakets and mounted the rack (obviously irrelevant if your using the OG steering box)
now i could turn attention to the link: The corsa colum uses a short splined link with a UJ on either end (available on ebay for a few quid if you dont have one). i discovered the spline allows it to be easily seperated into two parts - male and female. This is the female part - the part that needs modifying:
The VW and rascal both use a rubber donut....the original colums mount onto this with a simple plate and two bolts.....so i trimmed the bottom of the bottom UJ and welded on a plate drilled with holes to mount to the rubber donut. i welded this inside and out. If your not a confident welder get this done professionally - you really dont want it to shear.
To prevent damage to the UJ you have to do short blasts and then Cool it in water or the heat will seize the UJ. The end result is as above - a UJ with a bolted plate on the bottom.
All pretty easy?? well it gets easier. Vauxhall kindly designed the male and female splines so they slide up and down giving about 4 inches of adjustment Grin Grin Grin . So when I rejoined the female with the male half of the link all i had to do was connect the top half to the corsa EPS rack and then tap the female section down the male until it engaged with the Rack spline. Bolt it up...job done.
view from below - all linked up:
All i need now is a control module to fire it all up. Ill keep you posted on that one Wink I have a plan.
Fatboy
PostPosted: Mon Mar 17, 2008 10:31 pm    Post subject: corsa column Reply with quote
rjes-count me in for one of your kits asap!!!!
Dodgy wrists after a bike accident and this is the one thing that spoils my van! Well that and AAZ lumps that keep on giving up the ghost on me!!!
What sort of price would we be looking at for the basic system without speed sensors?
View user's profile Send private message AIM Address
mat*
PostPosted: Mon May 26, 2008 9:44 am    Post subject: Reply with quote
Hello has the kits you done worked well
justin pane
PostPosted: Wed Aug 20, 2008 5:32 pm    Post subject: power steering Reply with quote
Can anyone help with electric connections to the ECU, its a corsa unit Ive fitted to my 72 bay van, from the ECU there are 5 fine gauge wires that connect to the control module and 2 heavy gauge wires (red and brown), where do these 2 wires go ?
_666_
PostPosted: Sun Jul 26, 2009 6:45 am    Post subject: Reply with quote
hi rich,
do you have any completed pics of the unit ? ..specifically how you mounted it ?
also what did you do about the VW Ignition, and VW Stalks?
claw_finger
PostPosted: Sat Aug 01, 2009 10:07 am    Post subject: Reply with quote
I have a corsa c rack, can anyone recomend where to buy the adjuster box
it' going in a T3
PostPosted: Sat Aug 01, 2009 6:15 pm    Post subject: Reply with quote
_666_ wrote:
hi rich,
Did you see the pics on the first page of this thread ?
http://external.vwkd.co.uk/corsa1.JPG
http://external.vwkd.co.uk/corsa2.JPG
http://external.vwkd.co.uk/corsa3.JPG
http://external.vwkd.co.uk/corsa4.JPG
http://external.vwkd.co.uk/corsa5.JPG
I believe he is using the Corsa stalks and Sooby ignition... sure he'll confirm soon.
_666_
PostPosted: Sun Aug 02, 2009 1:25 pm    Post subject: Reply with quote
yeah i did see it but the way i understood what he said was that the pics are only the temperary brackets,
naturally i wouldnt mind not knowing how it was done, but my kombi is my daily driver so i cant pull it appart to try and fit the column in.. i need to know what i need to go it, and do it all at once.. Happy
PostPosted: Mon Aug 03, 2009 11:42 am    Post subject: Reply with quote
666- not much has changed from the above pics - the framework is still a temporary set up but it will just be refined and properly welded to make it final. As JP says i will use Corsa stalks and subaru ignition module...you dont HAVE to do this though.
I have just rememebred that you want more pics of the rack mounting etc - i will try to do this tonight!
_666_
PostPosted: Tue Aug 04, 2009 1:41 am    Post subject: Reply with quote
awsome, and yeah id preffer to use the corsa stalks myself anyway, out with the old and in with the new haha, it would go well with my Toyota V8 Engine :P
Page 4 of 6
