cali red Padawan
Posted: Fri Nov 14, 2008 7:20 pm Post subject: Does SVX engine fit 2WD with RJES support bar |
| I see svx conversions but they seem to always be done on syncro vans. Will the 3.3 fit under the engine lid on 2wd t25 using RJES engine support bar and bellhousing? Also is the newer 3.0 six cylinder a better fit? |
Posted: Sat Nov 15, 2008 2:23 am Post subject: |
There is no particular reason why EG33 conversions often tend to be done to Syncro's. There are 4 EG33 powered buses in the UK as far as I know. Two on the road (a 2WD and a Syncro), and two being biult (also a 2wd and a Syncro - btw, the Syncro is in Jersey too, and is having a brand new EG33 engine).
The EZ30 and EZ30R engines are newer, higher tech 3.0 litre versions of the six cylinder. They are conmplex engines, with variable timing and lift, etc. Only the EZ30 (MY00 - MY03) is suitable for use in VW conversions currently, unless you are into CAN bus electronics, and like a challenge.
All 3 variations of the flat sixes should fit RJES engine mounts no problem.
Did you fix the current drain on your battery successfully? _________________ Regards,
cali red Padawan
Posted: Mon Nov 17, 2008 6:25 pm Post subject: Does SVX engine fit 2wd t25 with RJES support bar |
| Hello Richard Yes battery drain problem has gone now. Im gutted to find out svx conversion over here is having a new engine fitted ,I was outbid a few months ago on ebay for a new engine and its the same one i suppose. No worries how are the exhausts/sumps getting on? Cheers Simon... |
Posted: Tue Nov 18, 2008 12:30 am Post subject: |
Hello Simon,
Glad the battery drain is solved. There can't be too many NOS SVX engines around! - yes, it'll be the same one. I was watching it on eBay at the time too.
The exhausts are finished, and available now. I've been that busy for the last few weeks that I've not had a chance to put them on the web site yet. The sumps are ongoing..... _________________ Regards,
easy-does-it Jedi Guardian
Posted: Tue Nov 18, 2008 6:38 pm Post subject: |
Sorry 'thread hijack'...are the exhausts N/A only or are there turbo versions? _________________ '76 bay going superfly TDI |
Posted: Tue Nov 18, 2008 9:32 pm Post subject: |
N/A only untilI find time to develop a turbo version. I't's on my to do list, but not at the top yet. _________________ Regards,
Posted: Sun Nov 23, 2008 1:16 pm Post subject: |
Hello Simon,
I noticed a customer who recently upgraded his Syncro by swapping the EJ22 engine for an EG33 currently has his old Syncro mount on eBay. I've e-mailed to ask whether it didn't fit the EG33 engine for some reason, or whether it maybe wasn't suitable for some other reason (such as moved the engine relative to the chassis, etc). _________________ Regards,
Posted: Mon Nov 24, 2008 5:56 pm Post subject: |
I just got areply from the guy with the mount for sale on eBay. He didn't use it because of the exhaust system he fitted to his EG33 engine, not because it did not fit the engine. _________________ Regards,
cali red Padawan
Posted: Wed Nov 26, 2008 4:16 pm Post subject: Does SVX engine fit 2WD RJES support bar |
| Hello Richard thanks for info , I was going to contact that ebay seller myself. Did you get my message about shipping costs for the exhaust ? Cheers Simon....... |
