Engine swap
Goto page Previous  1, 2, 3, 4, 5, 6
Norway
PostPosted: Sun Jan 18, 2009 5:19 pm    Post subject: Reply with quote
once again......thanks mate!!!!
Will try the stetoscope method.....didnt think of that.!!
Subsyncro =)
sven
PostPosted: Sun Jan 18, 2009 6:10 pm    Post subject: Reply with quote
If it's a distinct sound you can even find which cylinder that causes the sound by feeling with a standard flat screw driver. Just hold it loosely with your fingers and press the driver against the cover. It's pretty accurate and sometimes it's possible to feel which valve that causes the ticking.
EDIT: The adjustment is a really simple operation. Make sure the valve is closed (open up the spark plugs makes it easier) and then stick the "blade" - as Elusive wrote, either 0.20 or 0.25 (or 0.20 and 0.05 together) - in between the valve and the rocker (lifter). Then adjust with the screw on the rocker until it's tight. Don't tighten too much! You're supposed to be able to move the blade, when you feel a little bit of resistance it's perfect.
andy syncro-nutz
PostPosted: Mon Jan 19, 2009 5:03 pm    Post subject: Reply with quote
Is there not a procedure bleeding the hydralics on these engines?
www.syncro-nutz.com
PostPosted: Mon Jan 19, 2009 6:12 pm    Post subject: Reply with quote
Yup, go a page back and look at the last post
andy syncro-nutz
PostPosted: Mon Jan 19, 2009 7:43 pm    Post subject: Reply with quote
Thought ther was!
www.syncro-nutz.com
sven
PostPosted: Mon Jan 19, 2009 9:29 pm    Post subject: Reply with quote
Unless you didn't for this conversion after all:
I checked earlier in the thread, you posted that it's a -95. All 95's are with hydraulic lifters. My fault.
andy syncro-nutz
PostPosted: Mon Jan 19, 2009 10:19 pm    Post subject: Reply with quote
Ah that looks just like a choice tool for McGill, Think il fit one of them to his van rather than the 2.5tdi Laugh Out Loud
www.syncro-nutz.com
Norway
PostPosted: Tue Jan 20, 2009 6:57 am    Post subject: Reply with quote
OK!!!.Hydraulick lifters it is then!!!
New noice...probably a busted wheel bearing in the front.....this is qiute a pain in the neck job on a syncro right?
Subsyncro =)
Norway
PostPosted: Wed Sep 16, 2009 6:35 am    Post subject: Reply with quote
Hi there vw friends!! Grin
Stumbeled across this web page just now and came to remember ALL the good help i got from you guys last autum when i swapped my engine. Sorry to say that the car got sold. I was a student at the time beeing and i could not afford a new exhaust and front wheel bearing. So now im driving arround in a vw transporter T4 2,4D. A steady runner Wink. I miss my sobsyncro bus verry mouch from time to time, but i know the car is in good hands.
So thanks a lot guys (especialy Elusive and Rjes) for a LOT of help, patiente and a great forum =)=)=)
Subsyncro =)
Page 6 of 6
