How To Change Your Gearbox Input Shaft
Post new topic   Reply to topic     Forum Index -> Useless Information
Covin
PostPosted: Thu Apr 12, 2007 10:18 pm    Post subject: How To Change Your Gearbox Input Shaft Reply with quote
As I've just had to remove the extended Input Shaft from an old Gearbox I thought I'd do a step by step guide to show how it's done.
I suppose the process will be the same for all input shafts but it's the Extended Input Shaft that is shown because this is needed when you fit most adaptorplate kits
Input Shaft at bellhousing side
Step 1
Remove circlip from Right hand drive shaft flange.
Step 2
Remove the drive shaft flange.
Step 3
Remove the side cover from gearbox diff casing. You can now see the Input Shaft at the top running into another gear sleave.
Step 4
Remove the circlip on input shaft just where the splines start and enter the other gear cog/sleave.
Step 5
Once the circlip has been removed, the gear cog/sleave can be slid back to clear the inner splines, you can see the input shaft has a threaded end that can now be unscrewed by turning the input shaft anti-clockwise
Step 6
Input shaft is now unscrewed
Step 7
cog/sleave can now be withdrawn from input shaft
Step 8a
Remove the circlip from the input shat
Step 9
The input shaft can now be withdrawn from the Bellhousing side and job done
Hope this might help a few of you out as the manuals are rather vaugue. At least you can see what's involved and it's not really hard to do. Bit messy and smelly though
DARREN
I LOVE RUST ME
famous phil
PostPosted: Sat Apr 14, 2007 5:59 am    Post subject: Reply with quote
Hello nice one covin , can almost smell the nasty gearbox oil Grin
difference on the type t25's you need to remove bellhousing ,, not a job i thought ppl would like to do ,,,, so my kits use the stock box Happy
Covin
PostPosted: Sat Apr 14, 2007 7:54 am    Post subject: Reply with quote
To be honest phil, I think having to change the input shaft is a pain in the arse. Your setup sounds a much better idea and keeps things much more straight forward
I think I'll be making my own little extension to fit the flywheel/crank and bring the needle bearing out to fit the standard input shaft on my next conversion. . . . .Why pull apart a perfectly good gearbox ? It's just more work Grin
DARREN
I LOVE RUST ME
toadheaddesigns
PostPosted: Sat May 05, 2007 8:15 pm    Post subject: Reply with quote
can you do this with the box still in the car?
i cant really be arsed to take it all apart again
"Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
"It's not unusual."
Covin
PostPosted: Mon May 07, 2007 6:50 pm    Post subject: Reply with quote
I don't see any reason why you couldn't do it with the box still fitted
DARREN
I LOVE RUST ME
gerrelt
PostPosted: Tue May 08, 2007 6:56 am    Post subject: Reply with quote
Great how-to Covin!
homepage
VolksRomeo 13033 S 1.4 IE
72panelvan
PostPosted: Thu May 31, 2007 1:20 pm    Post subject: Reply with quote
Just trying to do this at the moment with a 2ltr box, I've slide the reverse gear fully forward but it seems like I need to lock the back section of the input shaft to unscrew the other bit? Is there away of locking it in position? I turn it anti-clockwise and it just turns forever!
Thanks in advance!
Tom
PostPosted: Thu May 31, 2007 2:38 pm    Post subject: Reply with quote
As far as I know there isn't any ways to lock it. Maybe try some menatrating oil on the joint to help free it.
72panelvan
PostPosted: Thu May 31, 2007 3:08 pm    Post subject: Reply with quote
will do, i'll try moving the reverse gear further forward too - looking at those piccies it looks like I should be able to see more of the other part of the input shaft - but it is a different box.
cheers!
72panelvan
PostPosted: Thu May 31, 2007 5:27 pm    Post subject: Reply with quote
Did it! Anyone removing the input shaft from a 2 ltr box, I found you had to move the centre diff bit around untill the hole on the diff allows the reverse gear to move along fully - even then on mine it had to pushed up at a bit of an angle to allow it move along enough.
cheers for the help
tom
toadheaddesigns
PostPosted: Sat Aug 04, 2007 3:55 pm    Post subject: Reply with quote
its a right fucking pain with the box still in the car, trust me i'm half way through....just the circlip on the existing shaft to do now then all back together
"Is it common?"
"It's not unusual."
gazmidas
PostPosted: Tue Feb 10, 2009 8:46 pm    Post subject: Reply with quote
My new shaft doesnt appear to have a threaded end, i havent looked closely and havent removed the old one yet either......
sounds like i could be hunting for a new one??
Gareth
1x Type 2 Vw Camper (1972),
1 x GTM Coupe Kit Car (1968),
1 x Austin Mini (1970),
1 x Sylva Striker Race Car (1995),
1 x Triumph Daytona 675 (2010),
1 x Golf TDI Estate (2001)
Post new topic   Reply to topic     Forum Index -> Useless Information All times are GMT
