Posted: Thu Aug 10, 2006 8:51 am Post subject: www.pdsracing.co.uk Makers of Adapter Plates/ Input Shafts
Thanks to Full Throttle for this one....
www.pdsracing.co.uk make adaptor plates and input shafts for ford 4cyl, rover k series & bmw motors, adaptor plate about 160 for a ford, input shaft about 250, as most 4cyl fords (apart from small zetec) are all the same pattern it will fit diesel or petrol options, email with your choice and they will come back with part no & price _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Prices for our adaptors range from £146.83 for the HC/207-3A Formula Ford to £545.00 for the LG/586 Chevy V8. Most are priced in the region of £265-295. The VW clutch shaft will work with a Ford adaptor of 1-1/8” thickness, other applications will require a clutch shaft to suit the adaptor. Clutch shafts are available from £215.00.
adaptors normerly kept in stock, specials can be made one of approx £600
