www.pdsracing.co.uk Makers of Adapter Plates/ Input Shafts
Post new topic   Reply to topic     Forum Index -> Shops (Online or Otherwise)
PostPosted: Thu Aug 10, 2006 8:51 am    Post subject: www.pdsracing.co.uk Makers of Adapter Plates/ Input Shafts Reply with quote
Thanks to Full Throttle for this one....
www.pdsracing.co.uk make adaptor plates and input shafts for ford 4cyl, rover k series & bmw motors, adaptor plate about 160 for a ford, input shaft about 250, as most 4cyl fords (apart from small zetec) are all the same pattern it will fit diesel or petrol options, email with your choice and they will come back with part no & price
rusty69bus
PostPosted: Fri Aug 11, 2006 10:17 am    Post subject: Reply with quote
err! jp this is the one I listed?
PostPosted: Fri Aug 11, 2006 10:43 am    Post subject: Reply with quote
Sorry for stealing your thunder there rusty69bus...
So big phat props to rusty69bus for this...
rusty69bus wrote:
in the sixtys lola race cars used vw transaxles modified by a company called hewland - see transaxle alternatives.
for those who want an adaptor plate, i have found a uk manufacturer
just remember to say where you found the link VWKD
http://www.pdsracing.co.uk/products/index.htm
reply from email sent -
Prices for our adaptors range from £146.83 for the HC/207-3A Formula Ford to £545.00 for the LG/586 Chevy V8. Most are priced in the region of £265-295. The VW clutch shaft will work with a Ford adaptor of 1-1/8” thickness, other applications will require a clutch shaft to suit the adaptor. Clutch shafts are available from £215.00.
adaptors normerly kept in stock, specials can be made one of approx £600
Post new topic   Reply to topic     Forum Index -> Shops (Online or Otherwise) All times are GMT
