1961 Bus Warning Lights
KSC2-303
PostPosted: Sun Apr 12, 2009 11:32 am    Post subject: 1961 Bus Warning Lights Reply with quote
Ive recently bought a 1961 VW Bus. I'm pretty m,uch a newbie to the classic VW scene and I have no idea what the warning lights on the speedo mean. There are three, two of wich are on; a red one on the left, and a green/yellow one on the right. Obviously there is one in the middle aswell, but that is not lit up. Please could someone tell me what they mean?
PostPosted: Mon Apr 13, 2009 12:07 am    Post subject: Reply with quote
One's an alternator light, the other is oil light. I can't help with the middle one, sorry!
If they dont' go out when you start your engine, turn it off. Both will be fatal.
A few suggestions for you:
1/ Join your local VW club
1/ Buy John Muir's "Keep your VW alive - for the complete idiot" (no, I'm not kidding)
3/ Check out http://www.volkszone.com/VZi/ if you look in the Tech section, Moby, Clarkson & Speedy Jim (no particular order) are demi-gods!
HTH
Joel
PostPosted: Mon Apr 13, 2009 1:11 am    Post subject: Reply with quote
splittys had pretty much the same speedo setup as beetles
the red light on the left is the charging system warning light
middle one is the idiot light for the turn signals
right one would have been green originally but they fade to yellow over time is the oil pressure warning light
vw didnt start labeling the lights till the late 60s
they just assumed people knew what they were
easy way to remember oil light from charge/generator light is they are alphabetical from left to right
ie G for generator comes on the left before O for oil on the right
hope that helps
KSC2-303
PostPosted: Wed Apr 15, 2009 9:41 am    Post subject: Reply with quote
Thanks for the replies guys, both have helped. I have just bought the book suggested and have already been looking for local VW clubs.
PostPosted: Wed Apr 15, 2009 2:36 pm    Post subject: Reply with quote
Where are you?
Whispers, there's a club section bit on Vzi, tell Bri VWKD sent you Wink
