futbus Initiate Jedi
Posted: Sun Apr 12, 2009 5:45 pm Post subject: Wide 5 Vented disc upgrade |
After being hasseled for some time we have finally produced a wide 5 vented disc kit. Our kit will run wide 5 as standard, but you can change part of the hub and bolt on any wheel combination required, ie if you want to run porsche wheels, just unbolt the wide 5 bit and bolt on the porsche bit so no additional spacers are required.
 _________________ www.futbus.com
Any machining needs give us a shout on 07866 581136
Located in south devon |
chuggaboom Jedi Master
Posted: Mon Apr 13, 2009 10:43 am Post subject: |
| whats the prices like on this |
Posted: Wed Apr 15, 2009 8:02 pm Post subject: |
All on the website www.futbus.com _________________ www.futbus.com
smartdriver Padawan
Posted: Sat May 16, 2009 4:36 pm Post subject: |
Hi,
Finally, somebody made vented disc's for a Crowfeet rim!
My question is this, what calipers do you use, and do you have a kit for the rear, for a splitty that is?
My intention was, because there was nothing for my split that would fit inside the Crowfeet rim, to use a Porsche 944 setup front and rear with matching Porsche rims.
The rear can be solid and it is a beetle setup.
Cheers,
Paul
BTW, i'll link you to the Dutch Splitboard  _________________ convertin' a VW T2 t1 '69 15 window "splitty" into a daily driver, to be continued....... |
