Norway Padawan
Posted: Sun Jan 18, 2009 5:19 pm Post subject: |
once again......thanks mate!!!!
Will try the stetoscope method.....didnt think of that.!!  _________________ Subsyncro =) |
sven Jedi Guardian
Posted: Sun Jan 18, 2009 6:10 pm Post subject: |
If it's a distinct sound you can even find which cylinder that causes the sound by feeling with a standard flat screw driver. Just hold it loosely with your fingers and press the driver against the cover. It's pretty accurate and sometimes it's possible to feel which valve that causes the ticking.
EDIT: The adjustment is a really simple operation. Make sure the valve is closed (open up the spark plugs makes it easier) and then stick the "blade" - as Elusive wrote, either 0.20 or 0.25 (or 0.20 and 0.05 together) - in between the valve and the rocker (lifter). Then adjust with the screw on the rocker until it's tight. Don't tighten too much! You're supposed to be able to move the blade, when you feel a little bit of resistance it's perfect. |
andy syncro-nutz Padawan
Posted: Mon Jan 19, 2009 5:03 pm Post subject: |
Is there not a procedure bleeding the hydralics on these engines? _________________ www.syncro-nutz.com
Posted: Mon Jan 19, 2009 6:12 pm Post subject: |
| andy syncro-nutz wrote: | | Is there not a procedure bleeding the hydralics on these engines? |
Yup, go a page back and look at the last post _________________ The advice you receive on here is worth the paper it's written on.
Posted: Mon Jan 19, 2009 7:43 pm Post subject: |
Thought ther was! _________________ www.syncro-nutz.com
sven Jedi Guardian
Posted: Mon Jan 19, 2009 9:29 pm Post subject: |
Unless you didn't for this conversion after all:
I checked earlier in the thread, you posted that it's a -95. All 95's are with hydraulic lifters. My fault.  |
Posted: Mon Jan 19, 2009 10:19 pm Post subject: |
Ah that looks just like a choice tool for McGill, Think il fit one of them to his van rather than the 2.5tdi  _________________ www.syncro-nutz.com
Norway Padawan
Posted: Tue Jan 20, 2009 6:57 am Post subject: |
OK!!!.Hydraulick lifters it is then!!!
New noice...probably a busted wheel bearing in the front.....this is qiute a pain in the neck job on a syncro right? _________________ Subsyncro =) |
Norway Padawan
Posted: Wed Sep 16, 2009 6:35 am Post subject: |
Hi there vw friends!!
Stumbeled across this web page just now and came to remember ALL the good help i got from you guys last autum when i swapped my engine. Sorry to say that the car got sold. I was a student at the time beeing and i could not afford a new exhaust and front wheel bearing. So now im driving arround in a vw transporter T4 2,4D. A steady runner . I miss my sobsyncro bus verry mouch from time to time, but i know the car is in good hands.
So thanks a lot guys (especialy Elusive and Rjes) for a LOT of help, patiente and a great forum =)=)=) _________________ Subsyncro =) |
