VW Disc conversion on a 69 bay
Nick-Rackham
PostPosted: Wed Sep 23, 2009 8:17 pm    Post subject: VW Disc conversion on a 69 bay Reply with quote
Noob question, please be gentle
69 bay on drums, wanting to go to 17" rims and discs all round. Is it possible to use stock VW Golf Discs, hubs and calipers (inc rear handbrake etc) onto the bay? I've looked at kits, but would much prefer to use stock VW components if possible.
Thanks
Nick
familyvan
PostPosted: Wed Sep 23, 2009 9:20 pm    Post subject: Reply with quote
I wanted to go with 17" Brm's from the new beetle, so i bought the wheels and then got the biggest brakes and calipers that would fit underneath the rims, i went with 312mm brakes with a 5 * 100PCD.
i then had a plate made up to bolt to my spindles which would mount the calipers to my spindles...
the hardest bit is finding someone to make the caliper mounts...
Nick-Rackham
PostPosted: Wed Sep 23, 2009 9:28 pm    Post subject: Reply with quote
Hi, yes, I read your restoration thread, took ages, but has given inspiration to go tdi Happy but back to the brakes, I've got a bay, not a split, are the spindles the same? will they accept golf hubs? or do I neet to modify the hubs too? Cheers, Nick
Nick-Rackham
PostPosted: Thu Sep 24, 2009 6:17 pm    Post subject: Reply with quote
Looking around it looks like vdubengineering do a billet hub and caliper that fits the bays that will take the VW discs and calipers! does anyone have any experience of these?
Caliper Bracket http://www.vdubengineering.com/products/billetcaliperbracket.htm
Hub http://www.vdubengineering.com/products/brakes/golf.htm
Thanks, Nick
PostPosted: Fri Sep 25, 2009 8:16 am    Post subject: Reply with quote
V dub engineering is based in Canada. I've spoken to Lanner in the past regarding a Porsche disc conversion for my type three. They where very helpfull and always quick to respond, although I never broguht anything as being a type three I had to send my spindles over there which was for my way to much agro.
As they are based in Canada be prepared to pay through the nose for the P & P and also dont forget to allow for custom handling charges too.
I used LA Performance up in Northampton for my brake conversion.
http://www.laperformance.co.uk/Brakes.html
futbus
PostPosted: Sat Sep 26, 2009 10:27 am    Post subject: Reply with quote
Give us a shout for disc conversion stuff using VAG items.
See www.futbus.com
www.futbus.com
Any machining needs give us a shout on 07866 581136
Located in south devon
Nick-Rackham
PostPosted: Thu Oct 01, 2009 4:26 pm    Post subject: Reply with quote
oops, just seen your seperate thread on vw discs! Question, I think I need late bay spindles? with 112 PCD and then source discs and calipers on Golf hubs. Need to machine the hubs and fit with bearings to fit the late bay spindles? Lastly machine up some brackets to mount calipers on spindles? Have I got that right?
Cheers, Nick. P.S. excellent job on the tdi conversion. already sourcing a 1.9tdi Happy
PostPosted: Fri Oct 02, 2009 1:15 pm    Post subject: Reply with quote
I have VW Corrado VR6 callipers on my bay-didnt need any adaptor plates-I just sent off my bay hubs and spindles and FUTBUS machined my uprights to except the new calipers and sorted me out with some VAG discs that slot straight on. He also rebuilt all my hubs and upright and assembled them together so all I had to do was bolt the lot on to my swing arms.
Give them a shout they are very helpfull, good and affordable.
Nick-Rackham
PostPosted: Fri Oct 02, 2009 4:30 pm    Post subject: Reply with quote
Superleggo
PostPosted: Thu Feb 11, 2010 11:07 pm    Post subject: Reply with quote
Alex
What master cylinder did you use. Are you running a servo?
Are you using VR6 calipers on the front or rear?
What are the discs do they fit under 15'' wheels
VW Camper 1971
VW Passat 2006
Lotus Elan +2 1968
Mini Moke 1974
Land Rover Series 2a 1967
DB5 replica Work in progress
Another day another car!
Smoothlookinbay
PostPosted: Sun Mar 28, 2010 6:29 pm    Post subject: Reply with quote
I'm just getting all the bits together for my brake conversion.
Specification so far:
Mk3 Golf GTI master cylinder and servo
Mk3 Golf GTI front brake calipers
Machined front spindles to mount calipers
Ford Galaxy brake discs vented front and solid back
Machined rear hubs to take discs
Home-made adapter to take galaxy rear calipers
The only thing I'm still worried about is the brake bias valve, mines disappeared! Has anyone else got rid of theirs?
It WILL be ready for the summer, just like it was going to be ready for last summer. And the one before that...
