Fitting DK 4 Speed gearbox into T25
cali red
PostPosted: Tue Oct 20, 2009 8:03 am    Post subject: Fitting DK 4 Speed gearbox into T25 Reply with quote
I ve tried to find out about putting an early DK box into a late T25 but got few answers as to how the linkage bars are fitted as in do i have to fit the complete linkage from the lawn mower vans.? I have the linkage rods but they have a different way of being fitted to the chassis etc. Any help would be great . cheers.
MostlyMonki
PostPosted: Tue Oct 20, 2009 4:00 pm    Post subject: Reply with quote
i thought they went in the same place, but the early linkage is thinner, so you need different bushes... at the gearbox end it just slides onto the guide "post" above the side-shift.
futbus
PostPosted: Wed Oct 21, 2009 8:27 pm    Post subject: Reply with quote
DK box is shorter, make some spacers for the nose cone end and lengthen the selector rod.
www.futbus.com
Any machining needs give us a shout on 07866 581136
Located in south devon
PostPosted: Sun Oct 25, 2009 5:31 pm    Post subject: Reply with quote
I make an extended front mount for the short early 4 speed boxes such as the DK, which puts the bell housing in the same position as the later 4 and 5 speeds.
