betsy! Initiate Jedi
Joined: 16 Nov 2009 Posts: 25 Location: Stoke-On-Trent
Posted: Tue Dec 15, 2009 10:36 am Post subject: Engine number.... |
I need to give my insurance company the engine number of the 2.2 legacy engine in my bug.
Any idea where I can find it or how it's normally made up so I know what I'm looking for?
Had a quick nosy with no joy  |
ricola Jedi Master
Posted: Tue Dec 15, 2009 1:08 pm Post subject: |
On the turbo engines it's on the top of the block by the bellhousing, unfortunately the intercooler brackets covers half of it which is a pain, might be in a similar position for NA tho? _________________ http://www.ricola.co.uk |
Posted: Tue Dec 15, 2009 1:18 pm Post subject: |
Hmmm, any idea what the format is? Like how many numbers etc.
I'v seen a few codes around the engine but not sure whether any of them are the right one! |
B4Tfink Jedi Knight
Posted: Tue Dec 15, 2009 5:22 pm Post subject: |
iirc its about eight digits probally with a couple of zeros to start no letters, as ricola says top of the bellhousing around the starter motor area / or if you have a reversed coolant manifold the exit end for that. looking from top of the engine that is.
does it not say on you registration docs you could double check against that?? _________________ 1988 T25 EJ25 n/a.. it just makes more sense that way.. |
Posted: Tue Dec 15, 2009 6:06 pm Post subject: |
I'v got the V5 for the original vehicle that the motor came out of, but the number is not on there.
It's not on my documents and I can't find it on the engine anywhere.
Great  |
B4Tfink Jedi Knight
Posted: Tue Dec 15, 2009 6:59 pm Post subject: |
that dosent sound good
it should be here
Posted: Tue Dec 15, 2009 7:58 pm Post subject: |
Nuvver photo for ya luv, 6 digit number just to the left of centre
Use mine if ya like  _________________ The advice you receive on here is worth the paper it's written on.
Posted: Tue Dec 15, 2009 8:22 pm Post subject: |
Ooooo, you little beauties!!!
Found it, thank youuuuuuuuu  |
