eirecamper09 Wannabe
Posted: Wed Mar 31, 2010 9:01 pm Post subject: how do i fix the alternator in this pic? |
hi
i have a 1.9tdi aaz engine fitted to my bay window. all is running really well but a wire has come away from the alternator. it seems that a piece of plastic(where the wire connects) has snapped off the plastic housing off the alternator. ive tried cliping it back in but to no avail. ive attached a picture to explain things better
anyone got any ideas as to how best repair this? is it posible to get a new plastic cover, or re-solder the wire straight to the broken contact? i'd rather not fit a new alternator?
[/img] |
Posted: Thu Apr 01, 2010 8:43 am Post subject: |
Hi and welcome to the forum.
I'll admit I can't quite see the broken contact in the picture.
However I can imagine the pickle your in so to mak a repair tithe contact you'd be best to solder a spade sonnector to it or a piece of wire with a spade connector at the other end.
If you only have a little of the original metal showing as the rest is buried in plastic try digging it out a little. Other then that you'll need to get plenty of heat into the showing metal when soldering the connection.
Best of luck fella. _________________ Think......
Posted: Thu Apr 01, 2010 9:13 am Post subject: |
Right had another look at it.
The black cover on the back can you not remove this? _________________ Think......
Posted: Thu Apr 01, 2010 1:48 pm Post subject: |
by the looks of the alternator id say it was a internal fan type (identified by a flat wide drive belt) is the plug on the side of the alternator a 2 pin plug with d+ and w stamped next to it? the plug is part of the rectifier and is difficult and expensive to replace means dismatling and desoldering the alternator to make a repair correctly. a good second hand alternator will cost alot less than the part new and is loads less hastle _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Fri Apr 02, 2010 9:01 pm Post subject: |
Euro Alternator Co
3a Mansion Street, Cambuslang
Glasgow
G72 7JN
fixed the problem for £55,00 top blokes |
Posted: Sat Apr 03, 2010 11:42 am Post subject: |
| eirecamper09 wrote: | Euro Alternator Co
Glasgow
G72 7JN
thats what i said bought a 120 amp other week from local scrapyard £20 didnt even have to take it off was on the shelf  _________________ 1964 rat 13 window deluxe 1Z tdi,
