Alex (FTS) Jedi Guardian
Posted: Thu Apr 22, 2010 2:03 pm Post subject: MOT- Do I have to have a indicator light on the dash? |
Ok just a quick one chaps-Does my dash indicator bulb have to work for the MOT. My indicators work fine-its just the bulb doesnt work or flash on the dash?
Cheers for any help!
 _________________ www.faltownskateboards.com |
Posted: Thu Apr 22, 2010 9:57 pm Post subject: |
Dunno. But when I go for my test I do the lights/indicators/wipers cos they've forgotten where the switches are
Edit: Quick Google shows this:
"driver's tell-tale works with respect to indicators, or there is an audible warning system."
From http://www.motester.co.uk/CarOwnersGuidetoTheMOT/WhatIsTested.aspx _________________ The advice you receive on here is worth the paper it's written on.
Posted: Thu Apr 22, 2010 10:02 pm Post subject: |
Yer come to think of it Ihadto dothe same last time too But I've got a new mot man now and dont want to take any risks-not sure how friendly he is yet! _________________ www.faltownskateboards.com |
Posted: Thu Apr 22, 2010 10:07 pm Post subject: |
Tell him it's a BMW, you never see their indicators working _________________ The advice you receive on here is worth the paper it's written on.
easy-does-it Jedi Guardian
Posted: Fri Apr 23, 2010 8:01 pm Post subject: |
| ElusiveStranger wrote: | | Tell him it's a BMW, you never see their indicators working |
Do they come with indicators??????.....
My dash light has never worked, but then again i also have to do everything inside for them too...they couldn't even find first gear  _________________ '76 bay going superfly TDI |
Posted: Fri Apr 23, 2010 8:51 pm Post subject: |
| Hi Al - just found this out for my dads car funny enuf- MOT man told me that strictly speaking yes it should have a dash indication or audible warning....but if you can hear the relay clicking then it would count as an audible warning and therfore no light required (my MOT man said he would pass that but wouldnt count on others doing the same!) |
Posted: Sat Apr 24, 2010 5:56 pm Post subject: |
yes it should work by law but most dont! is a 50p bulb worth a fail or a accident where someone pulls out you at a junction cause "i thought you were turning left mate" _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Sat Apr 24, 2010 7:44 pm Post subject: |
The bulb works it just stays on all the time and doesnt flash-even though the indicators and relay are all working and flashing lovely! Thanks for the heads up guys  _________________ www.faltownskateboards.com |
Posted: Sun Apr 25, 2010 5:42 pm Post subject: |
sounds like faulty relay then dude next time your at the boneyard find a golf and slip one in the pocket only a 2min job to swap and try _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Tue Apr 27, 2010 9:51 pm Post subject: |
Well I got another relay from the scrap yard and still no joy with the dash indicator light! Like I said the indicators work fine but as soon as I plug the bulb in the relay starts to buzz But if I turn the indicators on they work and the dash light works and the buzzing stops! Its almost like when the indicators are not in use there is a back current which is jibbing out the relay and making it buzz
Any one got any ideas?  _________________ www.faltownskateboards.com |
jamiegolf Force Sensitive
Posted: Fri Nov 19, 2010 8:12 pm Post subject: |
| Sounds like a dodgy hazard switch, my mk1 golf did this when the hazard switch packed up, indicators worked fine but buzzed when switched off and dash indicator light stayed on, changed relay, indicator stalk, dash led, then hazard switch, problem solved!! |
