apart from having to cut the Torsion Tubes
Make Uniball suspension system
run Coil Overs
reinforce half the rear end.
Modify the the gear shift rod ( still working progress)
move the rads forward..
make from and rear gearbox mounts
notch frame horns for CV joints
What is the rubber bung that fasterns to the rascal van steering rack called need to get one with a thread on it so I can make a bar the the ball joint that connects to the steering arm.
Posted: Sat Jul 03, 2010 9:05 pm Post subject:
familyvan wrote:
I don't know what all the fuss is about
run Coil Overs
MMMM that seems about all..
God it better work
weekend job then NOT!!!!! _________________ 1964 rat 13 window deluxe 1Z tdi,
