Posted: Thu Sep 28, 2006 9:57 am Post subject: Confused By My Adapter Set up ! |
Was stripping my gearbox down last night to switch over to my new 2ltr box and realised that my set up has no spacer and uses the original 1600 input shaft !!
I had a brief look at the fly wheel and tried to compare with my standard TD one and it does seems like it maybe a little deeper but not a lot if anything ! (trying to measure using my finger not usually a very acurate gauge !)
Anyway here are a few pics of my adapter plate.. how does it compare to everyone else ?
 _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Covin Darth Admin
Posted: Thu Sep 28, 2006 4:40 pm Post subject: |
Hmm . . . Strange one that jp
Your adaptor looks like a mirror image of both of mine.
My Covin one and the spare CVH one are exactly the same and I think from GBE.
Here's some info that might help.
Adaptorplate thickness = 40mm
Spacer thickness = 25mm
Input shaft sticks out from gearbox face = 35mm
All measurements are very accurate using vernier.
Dug the old engine out from it's covering, first time it's seen light in 2 years....
Here's a couple of pics
You can see my starter is on the oposite side to yours
Not sure if this will shed any light on the matter . . . . It's a strange one
I've just remembered... I've got a 3rd adaptor plate in the loft WITHOUT input shaft ? ? ? I wonder if it's the same as yours ? ?
Just have to get up there and find the thing now  _________________ DARREN
I LOVE RUST ME
www.vwbaywindow.co.uk - - www.covin.co.uk - - www.flat4dubs.co.uk |
rusty69bus Jedi Master
Posted: Thu Sep 28, 2006 6:37 pm Post subject: |
| odnt know if this will shed any light.. ford crossflow and ford pinto have starters on oppisite sides |
Covin Darth Admin
Posted: Thu Sep 28, 2006 6:44 pm Post subject: |
| rusty69bus wrote: | | odnt know if this will shed any light.. ford crossflow and ford pinto have starters on oppisite sides |
Yes Good point m8.... I wonder if jp has an older crossflow style adaptor plate. Still has the same bolt patern etc but this might just explain it  _________________ DARREN
I LOVE RUST ME
Covin Darth Admin
Posted: Thu Sep 28, 2006 10:49 pm Post subject: |
Right.... This one might add more confusion . . .
Been up in the loft and dug out my spare Ford CVH Adaptor plate. Bit of a strange one this
Here's some pictures.
I can only assume this adaptor plate uses the old VW starter motor as there's no starter fixings or machined area on it. It's also very thin compared to my other 2 Ford adaptor plates.
There's NO extended input shaft with this kit either by the way.  _________________ DARREN
I LOVE RUST ME
Posted: Fri Sep 29, 2006 8:19 am Post subject: |
| sounds simular to the pds racing sizes |
Posted: Fri Sep 29, 2006 8:39 am Post subject: |
Interesting pics there covin my adapter seems to fit very similar to your non loft version !
Bit more investigation required here me thinks ! _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
72panelvan Jedi Master
Posted: Sat Sep 30, 2006 6:22 pm Post subject: |
Just out of interest JP, are the clutch plates the same on the non turbo and the turbo engine? I know the diesel engine I've got has the original ford clutch plate and it's got a different spline pattern to the original 1600 input shaft. Might be that the conversion kit you have has a vw clutch plate which allows the use of the original input shaft?
tom |
Alex (FTS) Jedi Guardian
Posted: Fri Oct 13, 2006 2:39 pm Post subject: |
Ello ello to all. Been away for a few weeks and just spot this thred-very strange one JP as your plate does look very similar to the GBE kit. I knoe the kenedy kits look very similar but use a new modified fly wheel instead of spacers and possibly input shaft-not sure but I'll be interested in finding out! _________________ www.faltownskateboards.com |
Posted: Tue Oct 17, 2006 2:15 pm Post subject: |
just got an adaptor off someone on volkszone and it's got the starter on the same side as yours JP. It's made by hewland engineering who do the vw gearbox's. It also didnt come with a clutch release spacer but it might still need one and there is an extended input shaft.
I'll try and get some photos up
There is another guy on volkszone who has an adaptor for sale if anyones interested. |
Posted: Tue Oct 17, 2006 3:08 pm Post subject: |
Interesting..might have to meet up to compare and contrast them
You got a link to the other one for sale on vzi ? _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
