leeroy Initiate Jedi
Posted: Mon Dec 13, 2010 9:17 pm Post subject: Nose cone and Hockey stick question. |
Hi All
Just in the process of putting my original split bus nose cone and hockey stick onto an AM code box, I have noticed that the hockey stick has a small amount of play in the tube, at the end where it sticks out, will this leak and is there any seals available for the tube.
thanks
Leeroy _________________ 1965 south african kombi in lots of bits ej22 lying in wait. |
Posted: Tue Dec 14, 2010 7:27 pm Post subject: Re: Nose cone and Hockey stick question. |
| leeroy wrote: | Hi All
thanks
Leeroy |
im sure there are brass bushes in the nose cone that can be replaced to take the play out give bears a ring and get them to send you some new ones, there should be a lip type oil seal in the outer end of the nose cone _________________ 1964 rat 13 window deluxe 1Z tdi,
ping Jedi Master
Posted: Wed Dec 15, 2010 11:08 am Post subject: |
I got about an inch of hydraulic pipe that would slide over the end of the casting and glued in a 15mm id 25mm od lip seal. This "assembly" is them jubilee clipped over the end. Its a goot temporary fix.  |
