Simon Wannabe
Posted: Wed Nov 24, 2010 2:40 am Post subject: What Remote Thermostat Housing are you using? |
I have a EG33 SVX motor going in my split bus and we are close to mocking up the radiator underneath in the belly and wondering what remote thermostat housing people are using or recommend that's affordable:)
Thanks _________________ R&D...the only way!! |
rjes Jedi Guardian
Posted: Sat Dec 18, 2010 4:34 pm Post subject: |
I've never come across anyone using any kind of remote thermostat. I guess by the lack of replies, nobody else has either? _________________ Regards,
www.rjes.com |
Posted: Sun Dec 19, 2010 3:50 am Post subject: |
^^^^ WHS
But Ricola's working on one.
If you get it setup right, why bother? I've had no issues & judging by the lack of posts on here (or aussies, vanagons.net etc) nor has anyone else.
Subaru spent megabucks getting it right. *shrug* _________________ The advice you receive on here is worth the paper it's written on.
ricola Jedi Master
Posted: Sun Dec 19, 2010 11:41 am Post subject: |
People are/have done it, plenty of other threads around the web talking about it. Subaru spent money developing a front engined car with front mounted rad, clearly not what we have! The thermostat spacer idea is a half way house which should help.
To answer the original question, I'm using a BMW E30 external thermostat. The K series Elise is a pretty good equivalent situation where there are lots of variations of remote thermostat to solve problems of the original thermostat mounted at the return but even worse as it returns to the head!
Joel Jedi Master
Posted: Sun Dec 19, 2010 11:50 am Post subject: |
I was looking at Landrover discovery one for mine
Thought I'd try the subi one first though and it's still there now working to perfection.
I don;t run a heater though which is probably why it works so well _________________ 1974 1303 Germanlook Suba-Beetle
Posted: Mon Dec 20, 2010 7:41 pm Post subject: |
| Joel wrote: | I was looking at Landrover discovery one for mine
l |
the bmw engined 2.5td p38 range rover has that same part as well _________________ 1964 rat 13 window deluxe 1Z tdi,
Inane Cathode Jedi Knight
Posted: Tue Dec 21, 2010 6:51 am Post subject: |
I've got a heater i run full blast most of the time, especially when its freeeeeezing out. Along with metal coolant lines fully exposed under the car with the stock thermostat setup, i have not even once saw it get dangerously hot. Going up a hill holding it at high rpm it will creep up, the fan will come on, and it'll go right back down. I dunno what i have different, but the motor being in the back with the rad up front hasnt really had any effect that i can tell. It doesnt matter where the engine is, it's and engine it doesnt know where it is.
