Joined: 14 Jan 2011 Posts: 17 Location: Warrington, Cheshire UK
Posted: Mon Feb 07, 2011 9:59 pm Post subject: All Required Subaru Parts for EJ20 Turbo Conversion.
Hi everyone
We have just taken delivery of a 1994 Impreza WRX (JDM) Turbo for breaking, so I thought I would offer all the parts needed for a conversion on here first.
There is no service history and the clocks have been changed for a set of uk spec ones so the mileage can't be verified but it drives well and the engine pulls strong. It is still registering in kilometres so will have been still restricted to 180kph. It starts instantly, is not smoking or knocking.
The clutch seems ok, is not slipping or dragging, and there are no fault codes showing on the ecu. It has a td04 turbo so power output will be around 220bhp on the standard ecu. The car has a built in turbo timer so is allowed to cool down after use before switching itself off (can be removed).
The engine is still in the car and running, I will be taking a video of it tomorrow starting up and running to put on the website.
Parts included as follows :
Complete EJ20 engine including:
Block and heads
Manual Flywheel
Clutch
Release bearing
Timing belt, tensioner and covers
Alternator
PAS bracket
Inlet Manifold complete with throttle body and all sensors
Fuel rails, Fuel Pressure Regulator and Injectors
Intercooler and associated pipework
Exhaust headers
Exhaust Up Pipe
TD04 Turbo
Airflow Meter with intake pipework
Boost control solenoid and pipework
Bailey Vent to Atmosphere Dump Valve
Lambda Sensor
Charcoal Canister
Fuel Filter and Mounting bracket
Engine Mountings
Engine to Gearbox Studs, nuts and bolts
Starter Motor and bolts
PFR6B Spark Plugs
Ignition Coil Packs
Oil Filler and Cap
Dipstick
Cam Cover breathers
Coolant header tank if needed.
Electrical:
Wiring loom from dashboard forward
Fusebox
Ignition, Fuel and Main Relays
ECU
VIN details for future reference.
If there is anything I have missed out that is needed then please tell me and I will include it at no extra cost.
The price is £975 including palletised delivery to uk mainland postcodes. You can pay by debit or credit card or cash if you want to collect. I will deduct £100 for collection. Happy to ship to other destinations, please give me the details and I will price it up.
I am also happy to help with / answer queries, can provide support and parts for servicing at competitive prices.
