Steering wheel play??
BlackCosmos
PostPosted: Tue Mar 08, 2011 9:35 am    Post subject: Steering wheel play?? Reply with quote
seem to have some play in my steering wheel..it has a small amount off movement..if i replace ignition lock housing,will this cure it??or is it something else?? thanks..
sburford
PostPosted: Tue Mar 08, 2011 1:13 pm    Post subject: Reply with quote
there is meant to be a SMALL amount of movement, but if its more than 1" or so then under the van on the steering box there is an adjuster. you loosen the bolt then you can turn a screwhead a little bit, check it and if ok do up the nut tight. you need the front of the van off the ground to do this properly and dont move anything too much and take it on a easy test drive after to make sure all is well...
also prob. wouldnt hurt to change the steering box oil at the same time, might be 40years old... Happy
Shaun.
BlackCosmos
PostPosted: Tue Mar 08, 2011 2:59 pm    Post subject: Reply with quote
my mistake..should have put its on a t25!! the movement is up on the steering wheel,just ive seen pic of the ignition housing and it looks like it has a bearing in it..or is it the top part of the column i need??
sburford
PostPosted: Tue Mar 08, 2011 3:16 pm    Post subject: Reply with quote
ah my mistake. Happy
PostPosted: Wed Mar 09, 2011 9:50 pm    Post subject: Reply with quote
theres a bearing in the top that needs tension, if a aftermarket wheel has been fitted or the lock housing is set to low? this can cause the column to be loose in the tube. try moving the lock housing upward by slackening the allen key bolt in the casting and moving it upward if this doesnt sort it then it's new bearing time
BlackCosmos
PostPosted: Thu Mar 10, 2011 9:19 am    Post subject: Reply with quote
thanks for that..will give it a go later..
BlackCosmos
PostPosted: Thu Mar 10, 2011 2:51 pm    Post subject: Reply with quote
tried moving lock housing,didnt really move much..still the same..is the bearing housed in the ignition lock housing??
PostPosted: Thu Mar 10, 2011 9:48 pm    Post subject: Reply with quote
yes before condeming the bearing check the thin sleeve ring is still on the column
BlackCosmos
PostPosted: Fri Mar 11, 2011 9:11 am    Post subject: Reply with quote
does the sleeve go in top under steering wheel?? removed steering wheel and looks like there should be a sleeve in top of switch gear/column??
PostPosted: Sat Mar 12, 2011 8:31 pm    Post subject: Reply with quote
yes thats right its like a split top hat bush
BlackCosmos
PostPosted: Sun Mar 13, 2011 8:48 am    Post subject: Reply with quote
there is a sleeve,its about 40mm long with 3 notches in it..but it fits above bearing,not in the gap around column and bearing..??
