Early bay upgrade
Goto page Previous  1, 2, 3, 4, 5, 6, 7
T2 turbo
PostPosted: Tue Mar 29, 2011 5:42 am    Post subject: Reply with quote
Sorry guys haven't really kept you up to date with pics,
So heres what i've done since the bottom end went.
New motor with cosworth sump baffel plate fitted,
Gated the sump so oil stays around pick up under hard cornering,
Also made a cable shift conversion,
Fitted a 6 puck helix motorsport clutch disc,
Did the cambelt and fitted these rims i've refurbed 7.5&10x18
PostPosted: Tue Mar 29, 2011 7:52 pm    Post subject: Reply with quote
Nice! I'd love to do a cable shift one day.
markspencer
PostPosted: Fri Apr 01, 2011 10:02 am    Post subject: Reply with quote
Kia i'd like to take a look at the brackets on your g/box for the cable shift cause thats my next project over the winter, where exactly are you? I might pop up at w/end if thats ok?
foam cut to size
slimdadis
PostPosted: Sun Apr 03, 2011 1:20 am    Post subject: Reply with quote
Love the quality of the work.....professional.
My bus is a similar build.....been playing since 2001, but have started getting it looking finished (ish)...
check it:
http://forums.aussieveedubbers.com/viewtopic.php?tid=89592&page=1
cheers
T2 turbo
PostPosted: Tue May 03, 2011 12:03 pm    Post subject: Reply with quote
Been up to santa pod this w/end and after a couple of runs managed a 14.3 1/4, hopefully get a sub 14 this w/end
PostPosted: Tue May 03, 2011 2:50 pm    Post subject: Reply with quote
Love Are you aloud to be in the BWA now or do you have to be lawn mower for that?
Good work fella!
T2 turbo
PostPosted: Tue May 03, 2011 5:16 pm    Post subject: Reply with quote
Thanks mate but only splits in the bwa but have joined the usb which is just for bays that can run under an 18 1/4.
PostPosted: Thu May 05, 2011 6:27 pm    Post subject: Reply with quote
nice one dude bet your stoked 14 sec is super quick for a van!!!! my old mk1 20vt was over 200bhp and weighed nothing and fastest it ever ran at the pod was 14.4 so at 14.3 is mega for a bay all that work and the set backs were worth it in the end Grin
PostPosted: Mon Sep 19, 2011 9:13 pm    Post subject: Reply with quote
congrats on the Volksworld feature - they never do the work justice or cover enough tech IMO but still Inspirational stuff.....im just getting back into mine after a break so this has spurred me on!!!
Cheers Grin
T2 turbo
PostPosted: Tue Sep 20, 2011 11:17 am    Post subject: Reply with quote
Thanks Rich i'll post some pics up when i get chance.
I was really pleased with the feature but as you.ve said they can never actually show the amount of effort or heartache put in to a project.
southcoastcruiser
PostPosted: Wed Sep 28, 2011 4:33 pm    Post subject: Reply with quote
HI
very good job ! I have a question , what is the temp of your coolant with the rad on this position ? and the flow of your fans ?
I didn t see if you collect air from the front to the rad....
thierry
T2 turbo
PostPosted: Thu Sep 29, 2011 2:32 pm    Post subject: Reply with quote
The temp normally sits at 86-87 when on a roads but on motorways at sustained speeds of 70+ ;-) a little higher up to 90ish and the rad is ducted from the front.
Page 7 of 7
