1z vw into 59 split
Goto page Previous  1, 2, 3  Next
althesparky
PostPosted: Sun Jan 08, 2012 10:16 pm    Post subject: Reply with quote
well i havnt been on here for a while as ive been hard at work on the tdi conversion! i thought its about time i got some photos up of my progres!
collection of parts......
091 2litre box
adaptor plate
early bay rear end
1z tdi motor
mounting block for nosecone
althesparky
PostPosted: Mon Jan 09, 2012 8:03 am    Post subject: Reply with quote
first job is pull the old 2.4 type 4 motor and box
and the frame horns
section removed for my custom nosecone mounting block
althesparky
PostPosted: Mon Jan 09, 2012 8:11 am    Post subject: Reply with quote
early bay irs fitted
cosworth alloy rad fitted
shock relocation brackets made and fitted
rear chassis boxed in
althesparky
PostPosted: Mon Jan 09, 2012 11:22 pm    Post subject: Reply with quote
sort the wiring
fly by wire throttle
criuse control
fit the engine
althesparky
PostPosted: Mon Jan 09, 2012 11:39 pm    Post subject: Reply with quote
engine in with rear mount, engine sitting on 2x hydro mounts
6 rib 2 litre bay box, overhauled by bears and fitted with higher ratio 3rd and 4th and internals uprated to handle the torque
exhaust system
trim up rear valance
Sloride
PostPosted: Tue Jan 10, 2012 12:33 am    Post subject: Reply with quote
I love that rad set up. Looks very slick and doesn't hang down low at all.
Do you have any pictures of it before it was mounted so I can get a better idea of how you did it?
Secondly, what hydro mounts did you use?
Great work!
Craig
2007 VW GTI
1972 VW Westfalia
splitbusvanatic
PostPosted: Tue Jan 10, 2012 6:27 pm    Post subject: Reply with quote
nice work done here.
well done.. Happy
trev
PostPosted: Wed Jan 11, 2012 11:49 pm    Post subject: Reply with quote
what's the story with the 1Z ECU, do you need to have it de-immobilised? After that does everything work OK?
and why the new front tranny mount?
althesparky
PostPosted: Thu Jan 12, 2012 8:40 am    Post subject: Reply with quote
Hi mate, I have kept the factory immobiliser and wired it thru my cobra immobiliser (see cruise controll picture)
The reason for the new nose cone mount is because I,m using a baywindow 091 box rather than the standard swing axel box , there are several ways of mounting these but I wanted to keep it like it fixed in a bay window hence the bracket ......
Yes everything works, I've wired in the diagnostic port and have had vag com hooked up to it and it's not showing any error codes!! I have wired in everything it had when it was in the golf, ie clutch pedal switch and both brake switch circuits, I've also got the low water level sensor working which will flash the small led which I have put in above the temp gauge
The orange light is the glow plug warning light but this also tells you if you have any faults by flashing
althesparky
PostPosted: Thu Jan 12, 2012 8:41 am    Post subject: Reply with quote
Hydro mounts were mk3 golf tdi
trev
PostPosted: Thu Jan 12, 2012 1:21 pm    Post subject: Reply with quote
very nice work. Nice that all the factory gizmos work too Happy
PostPosted: Sun Jan 15, 2012 11:09 am    Post subject: Reply with quote
nice work there dude have you driven did the van yet? did you fit a vehicle speed sensor in the speedo cable if not you will get a fault code when the cruise is switched on and the ecu is enabled p.s. what 3rd and 4th gear ratio did you go for ive got a 0.70 4th in my 091 spot on for motorway in a split Grin
Page 2 of 3
