A piece has broken off my starter motor. HELP
splitbusvanatic
PostPosted: Tue Feb 21, 2012 6:57 pm    Post subject: A piece has broken off my starter motor. HELP Reply with quote
Basically the piece that broke is like the bit pictured below.
My starter is for T25 Diesel.
And the material is like a BakeLite type of hard plasticky housing at the back of the solenoid.
Has anyone any idea what to use to glue the part back on.
I'll get an actual pic of the piece tomorrow.
Thanks In Advance.
D.C.
Superleggo
PostPosted: Tue Feb 21, 2012 10:10 pm    Post subject: Reply with quote
I would go for a high quality epoxy as it is non conductive and will act as an insulator. Go for a clear one as they are less heavily filled. Araldite or similar should be fine.
Light abrade and clean with meths and should be ok.
splitbusvanatic
PostPosted: Tue Feb 21, 2012 10:19 pm    Post subject: Reply with quote
Cheers Bud.
I'll give it a go.
PostPosted: Thu Feb 23, 2012 7:40 pm    Post subject: Reply with quote
buy a new solinoid from a good auto electical place and swap it, its only held on with 3 screws and you can bet if you bodge it it will let you down when you most need it
splitbusvanatic
PostPosted: Thu Feb 23, 2012 10:53 pm    Post subject: Reply with quote
I took your advice before you gave it. LOL
I found an old tdi Passat starter and did Exactly that.
Swapped over the solenoids.
Sweet as a nut.
PostPosted: Fri Feb 24, 2012 7:03 pm    Post subject: Reply with quote
Sweet as a nut.
you just know it would have let you down at midnight on a sunday when it was raining and you were parked up hill Grin or it would have if it was mine Grin
Superleggo
PostPosted: Fri Feb 24, 2012 9:43 pm    Post subject: Reply with quote
I could not agree more with you 13 window. Better to fix once and for all. But epoxy would have got you to the scrap yard
