Calling "13 Window Deluxe" I need your brains
splitbusvanatic
PostPosted: Sat Mar 31, 2012 12:02 pm    Post subject: Calling "13 Window Deluxe" I need your brains Reply with quote
Im in the middle of fitting a Porsche 944 non turbo brake setup to my bus.
I've the easy bit done.
The Hubs and Discs and Calipers mounted onto my Bus Spindles.
However.
I remember you saying you have a Servo from a Golf fitted to your Bus
And like me. Your Bus is a LHD.
Do you think the 944 servo is too big to fit.?
What size is yours. ?
If by any chance did you take some photos of your servo installed ?
If you did. I'd be grateful to see them.
Here is my current predicament.
All the best.
D. C.
splitbusvanatic
PostPosted: Sat Mar 31, 2012 12:55 pm    Post subject: Reply with quote
Unless I do what RubberChicken did.
And mount the Servo with MC on the right hand side and make up a linkage like he did.
PostPosted: Sat Mar 31, 2012 11:37 pm    Post subject: Reply with quote
Can you not fit a remote mounted servo instead?
I run the 944 master cylinder but without the servo on mine.
splitbusvanatic
PostPosted: Sun Apr 01, 2012 4:51 pm    Post subject: Reply with quote
Thanks for the a reply Kai.
Looking at the price of VW Jim's Remote servo
it's 300 + about 20 to post to Ireland.
That's 320 pounds/ 383 Euro.
Not to mention pipes and fittings after that.
I figure if I persevere with the Direct Action Servo.
I'd save myself a few quid.
Looks like there's gonna be plenty of room on the right hand side of the front beam. (Absence of steering damper on that side etc)
If I can mount a linkage going Across to the left and swivelling from the action of the pedal push pin. If that makes sense.
I'll be in business. I hope.
PostPosted: Sun Apr 01, 2012 7:47 pm    Post subject: Reply with quote
Sounds like your going to make something similiar to the mark 1golf setup then. Looks very interesting what your going to achieve.
I didn't realise those remote servos cost that much.
PostPosted: Sun Apr 01, 2012 8:04 pm    Post subject: Reply with quote
hi on my van due to it being converted to rack and pinion i have the steering shaft running down the drivers side chassis leg and through the axle where the servo would usually be positioned so the servo has be located on the passenger side with a rotating type remote linkage similar to the one in the above photo. I had 3x vw golf servo's on the shelf, i think they were 7" 8" and 9" i went for the 7" one from a base model mk2 golf in the end as it easily cleared the handbrake cables and other junk under there. with the 7" servo i fitted and a 22mm master cylinder the brakes are nice and light with great feel i will try and find a photo on my old computer for you
splitbusvanatic
PostPosted: Sun Apr 01, 2012 9:08 pm    Post subject: Reply with quote
Plenty of Single Stage Lockheed Servos knocking about.
About 100 pounds apiece on eBay.
I'd need two and still have to retro fit them.
Funny you mention the mk1.
I was only looking at my own Mk1 Golf Servo setup the other day.
And I have two other scrapped Golfs.
A Mk1 and a Mk2.
I think the Golf setup pulls on pressing the pedal and the linkage at the servo side obviously then pushes the plunger at the back of the Servo.
I must take closer look at it.
Maybe I could fab something up using the scrap cars.
They're both chicken houses with concrete floors right now Happy
Cheers. I'd be Grateful.
Having test fitted my 944 servo (it's big) on the non driving (right) side of my bus. There's plenty of room.
I suppose it will be easy enough to Make up a Rotating linkage. And weld it to my Beam.
Your setup sounds similar to The Green Beam above. RubbaChicken's.
splitbusvanatic
PostPosted: Tue Apr 03, 2012 10:37 am    Post subject: Reply with quote
Ok.
Little update.
I've Mounted my Servo.
Made up a bracket and welded it to the Original Splitty Beam.
On the opposite side to the Brake pedal.
So. If you look at the beam painted green
Above. It's RubbaChicken's split with a bay beam.
Anyway. His servo is mounted opposite side also.
That linkage going from brake pedal/drivers side is from a Ford Fiesta I think.
Lucky enough. On my uncles farm. He has a '92 scrapped Ford Escort van.
I just checked there, SAME LINKAGE.
I'LL post pics once I'm in better signal. (updating from phone here)
Just have to remove it now.
The engine is still in the van.
So bit trickier.
