big.g.dubman Force Sensitive
Posted: Sun Apr 15, 2012 3:12 pm Post subject: |
| right ive cracked it i think starts poo hot runs alot better still backfires a bit but i think that maybe down to no airfilter on ,had enough now for the day (8 hours for 1 bloody wire lol)thanks for everyones help |
easy-does-it Jedi Guardian
Posted: Sun Apr 15, 2012 3:27 pm Post subject: |
| big.g.dubman wrote: | | right its official i am a hungover twat that should pay more attention to what i am doing, can anyone point me in right direction before i set my van on fire |
Ahh the good old days , reminds me of my whole build  _________________ '76 bay going superfly TDI |
Posted: Sat Apr 21, 2012 1:42 am Post subject: |
Filter makes no difference TBF unless you're driving through rocks, sandstorms etc. It mearly filters crap/restricts airflow, which the ECU compensates for.
Now, what really might make the difference is....reading the stickies (at the top of this section), which do ask you to post the year of donor engine
I know you posted the ECu number etc but it ain't worth bobbins with Scoobies
Engine, Donor and year.
You might owe me a "slab" and JP (well it's his site) some cookies after.
I'm negotiable on "slabs" - "Lava java" and "Morgan's Spiced" _________________ The advice you receive on here is worth the paper it's written on.
Posted: Sat Apr 21, 2012 12:14 pm Post subject: |
Yea mate no worries. The doner was a 1992 2.2 n/a
thanks |
Posted: Mon Apr 23, 2012 4:28 pm Post subject: |
| right ive been out and fiddleing with the van now starts great but seems to be hunting on idle asthough timing out also still backfire when you rev hard and then take foot off gas.so ive checked all my leads an plugs and they are giving a good spark ,so been doing some searching on here and my doner was a automatic so wondering if the belt has jumped a tooth is there a way for me to check that without taking the pully and plastic off the plastic has degrees marked on it cheers for the help |
Ianbott Jedi Knight
Joel Jedi Master
Posted: Tue Apr 24, 2012 3:10 am Post subject: |
| big.g.dubman wrote: | | right ive been out and fiddleing with the van now starts great but seems to be hunting on idle asthough timing out also still backfire when you rev hard and then take foot off gas.so ive checked all my leads an plugs and they are giving a good spark ,so been doing some searching on here and my doner was a automatic so wondering if the belt has jumped a tooth is there a way for me to check that without taking the pully and plastic off the plastic has degrees marked on it cheers for the help |
The hunting idle is a really common problem, it's the Idle Control Valve needing a good clean out.
They gum up with crap and start doing that.
The back firing on over run is probably also related, if the ICV isn't shutting properly on over run you will get the popping and back firing.
Also a muffler leak or just a muffler system that is just too free flowing can cause it too. _________________ 1974 1303 Germanlook Suba-Beetle
Posted: Tue Apr 24, 2012 7:32 pm Post subject: |
| Right had a look at the icv tonight and it turns out i had a air leak on the blank off pipe so resealed that and it now idles great and only pops a bit. Thanks for all your help |
