BlackCosmos Padawan
Posted: Mon Apr 23, 2012 8:30 am Post subject: scooby powered.. |
| im running a scooby turbo in my t25, now ive been getting gear selection problems in 1st and reverse..i thought it was a selector problem but now when van is ticking over im getting noise/rumbling from rear,pretty sure its not engine coz when i press clutch the noise goes..is there any way to determine if its gearbox is knackered?? or could it be stuck between gears?? it does still drive ok..thanks.. |
paulvandenton Padawan
Joined: 10 Jun 2010 Posts: 58 Location: Bethnal Green
Posted: Mon Apr 23, 2012 10:49 am Post subject: |
check your cv joints, i have bust 3 now.
Is one of your driveshafts turning?
just a thought |
BlackCosmos Padawan
Posted: Mon Apr 23, 2012 11:55 am Post subject: |
| only get the noise when not moving,seems to drive ok ,havnt been far as dont wanna push my luck and it goes bang!! |
Posted: Sun Apr 29, 2012 1:33 am Post subject: |
Press the clutch and the noise goes...not a g/box fault then.
Adjust clutch, sounds like it may be dragging.
VW boxes are straight cut in reverse to my knowledge (I'll stand corrected on this) and might sound whiny in reverse _________________ The advice you receive on here is worth the paper it's written on.
BlackCosmos Padawan
Posted: Mon Apr 30, 2012 5:30 pm Post subject: |
| turned out to be gearbox,noise got worse while driving..well ive got a dk box coming and thanks to rjes the bits to fit it too..thanks for advice.. |
