Hayleyjosephfrances Wannabe
Posted: Thu Nov 15, 2012 2:47 pm Post subject: Temperature gauge and wiring |
Hi, I am currently in the planning stages for a conversion of my 71 bay window to a EJ20 lump. Could really do with some advice on how a temp gausge would be set up and wired in to the circut. Also oil pressure. I am guessing it wires to the ECU some how but cant find a thread to tell me how. Any help would be appreciated _________________ Looking forward to reliability and a few less trips on a recovery truck |
Obonobo Jedi Knight
Posted: Fri Nov 16, 2012 3:59 pm Post subject: |
Hi!
Get a wiring diagram for your lump and check out the plugs of the ECU: for both the gauges wires go from the ECU to the instrument panel. Hook those up to your own gauges and you're done! _________________ Greetings from Sietze
Joel Jedi Master
Posted: Sat Nov 17, 2012 8:49 am Post subject: |
Does yours have 2 temperature senders in the coolant manifold or just one?
the ones with 2 are easy, just unscrew out the old subaru sender and screw in the new one that belongs with your gauge but if there is only one you would need to fit a gauge sender, few different ways, either drill and tap the manifold or get an inline hose adapter.
And for oil pressure the sender is just under the alternator, connect the original VW oil light wire straight to it. _________________ 1974 1303 Germanlook Suba-Beetle
