thermostat on my scooby t25 will not open.
Goto page 1, 2, 3  Next
jonathan
PostPosted: Sun Dec 09, 2012 3:42 pm    Post subject: thermostat on my scooby t25 will not open. Reply with quote
hello,
Iv done a rjes subaru conversion to my t25 and love it,very happy with the parts and service that i got from richard. I have ran it for ten months with no overheating problems,so i gather i have done the conversion right. Then it started to overheat and build presure, tried three different thermostats and can not get the water to circulate around my bus,put a new rad on as the last one blow a hole and rang the bus with no thermostat and everything works fine,all flows well, did 500 miles round scotland with no probs, but i want a thermostat in, as the vans aways running cold and got no heating,put another new thermostat in and straight away water will not circulate,
any ideas why this is happening,
the thing im puzzled on is why after running sweet for ten months then changing a broken thermostat for three different ones,which look the same as the old one,will it not work now,
cheers jonathan
Sydney
PostPosted: Sun Dec 09, 2012 5:31 pm    Post subject: Reply with quote
Could you post a diagram of your cooling system?
Did you use the bypass valve?
Any collapsed pipes?
Sydney
Obonobo
PostPosted: Mon Dec 10, 2012 7:22 am    Post subject: Reply with quote
Tip: get a thermostat from the dealer. The aftermarket ones don't open up well and the opening is smaller than OG. I thought there's an image of the difference on here somewhere.
That could make the difference! Good luck
Greetings from Sietze
jonathan
PostPosted: Mon Dec 10, 2012 8:44 am    Post subject: Reply with quote
il try post one but not the best with computers, by pass valve is on no collapsed pipes i dont think,as asoon as i take the thermo out the water flows and all pipes warm up and rad aswell, its ran rine for ten months which makes me believe iv done the conversion right.
its a strange one
jonathan
PostPosted: Mon Dec 10, 2012 8:46 am    Post subject: Reply with quote
Cheers pal, im on my way to buy a subaru one now, my after market one looks like the one i took out but anythings worth a go,il let you no how it goes
PostPosted: Mon Dec 10, 2012 9:37 am    Post subject: Reply with quote
your putting it in the right way up??
hole should be at the top
Obonobo
PostPosted: Mon Dec 10, 2012 11:38 am    Post subject: Reply with quote
For future reference: I found 'an' image. It's not mine (but from them), but it shows what I found when comparing measurements on online shops.
jonathan
PostPosted: Tue Dec 11, 2012 8:12 am    Post subject: Reply with quote
Mine looks like the one on the left,im waiting for my one from subaru to turn up and give that one a go,it will be the forth iv tied
jonathan
PostPosted: Tue Dec 11, 2012 8:21 am    Post subject: Reply with quote
im putting it spring side into the engine,
PostPosted: Tue Dec 11, 2012 11:03 am    Post subject: Reply with quote
Spring towards the engine, that's correct. Also their is a hole/valve/ flappy thing. It's pictured on the oem thermostat at the top. That should be at the top.
I'm thinking its going to be your coolant system design. Or a loose hose allowing air into the system then possibly causing an air lock.
jonathan
PostPosted: Tue Dec 11, 2012 3:59 pm    Post subject: Reply with quote
got new subaru thermostat in, still over heats.so after trying four now still wont work. we got the air locks out i think,,rad is full, header tank half way.
i will keep trying
Page 1 of 3
