ej22 to ej20
big.g.dubman
PostPosted: Wed Dec 12, 2012 9:18 pm    Post subject: ej22 to ej20 Reply with quote
hi all my ej22 n/a is buggerd needs heads working and waterpump ,so untill i can afford to get all this done was going to put a ej20 n/a in to tie me over.my question is ime running a r jes bellhousing would the clutch and flywheel work allso will i be able to use my existing loom
thanks
Obonobo
PostPosted: Thu Dec 13, 2012 11:11 am    Post subject: Reply with quote
As far as I know, you can use the bellhousing for the whole range of n/a's. Loomwise, I think you can use it, but can't be sure.
Greetings from Sietze
Joel
PostPosted: Sat Dec 15, 2012 11:10 pm    Post subject: Reply with quote
Every EJ engine, the EG and I think even the EZ and diesel engines all use the same bellhousing, the later ones just use a couple of extra bolts.
Easiest thing is to just find another EJ22 or an EJ20 thats before 99ish and bolt your manifold to it.
It's rare that the manifold loom matches up, they change almost every year.
Usually repairs on these engines cost more than another used engine.
big.g.dubman
PostPosted: Mon Dec 17, 2012 10:17 pm    Post subject: Reply with quote
cheers for help guys swapping the manifold sounds an easy fix just got to keep my eyes out for a cheap lump Happy
