Joined: 14 Jan 2011 Posts: 17 Location: Warrington, Cheshire UK
Posted: Sat Oct 08, 2011 9:01 pm Post subject: Subaru 2.0 Engine Conversion Kit
I have a conversion kit based on a 2003 2.0 SOHC non-turbo EJ20 engine with 81000 miles on the clock. It is from an automatic so doesn't have flywheel, clutch and starter. I can include a turbo flywheel and bolts, used clutch and a turbo starter for an extra £50. You can then fit a pull type clutch or have the flywheel redrilled to take the push type clutch.
Price is £750 inc UK mainland pallet delivery, or £800 with the flywheel etc.
Being from a late car it has the Denso mappable ecu with matching transponder key. Everything else you need from a Subaru is included.
Startup guarantee given, new timing belt, oil and filter should be fitted before starting. We can fit a new belt for you in advance for extra £60 so it is ready to fit just needing the oil change. Engines have to be shipped with no oil.
Engine is still in the car so can be heard running, it runs very nice. Compression test will be carried out before removal and results provided. Car is being broken for spares due to rear end damage.
Happy to provide support during pre and post installation to help you along if you have no prior Subaru knowledge.
Anyone interested then please contact me on 07541 016047 or via message, or the website www.scoobysplit.com
i purchased my engine from this company
first class service with surport after delivery
ive had my conversion for 18 months now with no problems
i highly recommend this company for all your subaru parts/ enginee spares etc _________________ 1978 twin slider panel van
fitting a ej20 conversion with rjes parts
