VSS Problem ( not the usual one)
Sydney
PostPosted: Tue Apr 02, 2013 9:37 pm    Post subject: VSS Problem ( not the usual one) Reply with quote
Hi,
I have an EJ20 fitted to a 1975 bay and have a Brantz BR4 VSS installed between the speedo cable and the speedo. The problem is that it causes the speedo to jump around, quite violently at low speeds, and clicks very loudly while driving. I undid it tonight and it feels like there is a bit of resistance at each of the 4 'pulses' as it rotates.
Has anyone else had this problem with this type of VSS?
It has three wires, +ve, ground and ECU. Does anyone know if the RJES VSS has the same wiring and if it might be a direct replacement?
Thanks.
Sydney
PostPosted: Wed Apr 03, 2013 8:43 pm    Post subject: Reply with quote
Does anyone know what the ECU uses the VSS data for?
Is it simply to tell the ECU that the vehicle is moving in which case the VSS pulse rate is not relevant as long as it is pulsing?
Or does the ECU need to know how fast the vehicle is moving in order to adjust the fuel, emissions, or something else, in which case it's important to feed it with the correct pulse rate for the speed.
The reason I ask is that some sensors output 4 pulses per revolution and another outputs 5 per revolution, and I want to understand if it makes any difference to the ECU.
Thanks
PostPosted: Thu Apr 04, 2013 7:07 pm    Post subject: Re: VSS Problem ( not the usual one) Reply with quote
Thanks.
Those are the wires on my RJES speed sensor. Works beautifully and does not effect the speedometer reading.
My 1995 4 plug ecu will throw an error code when the speed sensor isn't functioning. It will send the vehicle into limp mode when it's kicking off about the speed sensor.
Sydney
PostPosted: Thu Apr 04, 2013 8:43 pm    Post subject: Reply with quote
Thanks Kai. I may get an Rjes sensor then. sounds like it might be a direct replacement.
I can't understand why it's doing it. I'd like to take it apart but worry that it would never work again. I might disconnect the vss from the speedo for now to avoid damaging the speedo.
PostPosted: Mon Apr 08, 2013 8:38 am    Post subject: Reply with quote
I'd strip it. It doesn't work anyway so you have nothing to lose by taking it apart. Grin
flowervanman
PostPosted: Sat Apr 13, 2013 7:57 am    Post subject: Reply with quote
I had the same problem after fitting an rjes vss, I cured it by repacking the back of the speedo with grease. Might not be your problem but worth a try!
Sydney
PostPosted: Sun Apr 14, 2013 3:13 pm    Post subject: Reply with quote
I've done some further investigation. It seems that it's not the sensor afterall but possibly the cable. The clicking occurs once per wheel revolution not 4 as I first suspected. I tried connecting the cable directly to the speedo and it continued to jump, however the cable on its own seems to rotate Ok when not connected at all. The cable sleeve was shortened in order to fit the sensor and I think the cable may have been damaged somehow.
How did you gain access to the back of the speedo to repack it Flowervanman? You're right, it's worth giving it a try while I have the dash out.
flowervanman
PostPosted: Sun Apr 14, 2013 4:10 pm    Post subject: Reply with quote
Nice and easy, unscrew the cable from back of speedo, put some grease on ya finger and push it in the hole, I got this tip off another forum and its certainly cured the same problem for me! Grin
