Danchaff Wannabe
Posted: Sun Mar 24, 2013 10:22 pm Post subject: Radiator sizes and pipework material |
Hi, I'm looking t o move my radiator from the back of the engine to under the body on my 78 bay with an ej22. I'd be interested if anyone knows the dimensions of the usual rads fitted in this position? Fellows speedshop have a lovely aluminium rad but don't think I can stretch to one yet so might have to either relocate my existing or find a second hand one that will offer adequate cooling? Also I'm wondering which material to use for the pipes? Reading the Rjes site he advises against copper so I was wondering which other materials people have used? And whether its rigid or flexible? Also what sizes are most suitable?
Thanks Dan. |
Obonobo Jedi Knight
Posted: Fri Mar 29, 2013 9:48 am Post subject: |
Hi Dan,
I don't have any measurements on me, but anything that fits between the chassis rails is good! VR6 rads work, I have a Citroen Xsara one, other have Jag XJ40's.
Concerning piping, I used central heater pipes for the stretches and hoses for connections between components. Using metals piping you already loose heat on the way to the rad, but risk rusty pipes after a while. Hoses are easier to route, but more expensive. I have seen people use T25 pipes as well. They're made of some sort of plastic, don't know what kind, though.
Hop this helps! Link to my thread in signature. _________________ Greetings from Sietze
Posted: Sat Mar 30, 2013 10:14 pm Post subject: |
I have an XJ40 jag rad
pipe options: some have used pvc stuff you pipe up water troughts etc with on farms but its not that flexible, 28mm copper is easy to work but expensive and there is this theoretical risk RJES mentions, I have a set of MGF heater pipes too I might investigate using - they are steel so will eventually rust but are cheap and easy to modify.can get heavy duty rubber hose too which JP on here is using - I think its reasonably cheap and flexible. |
Posted: Sat Mar 30, 2013 10:24 pm Post subject: |
I went with 28mm copper, fully aware of the risks involved however I'm sure using coolant reduces this as well as preventing the contact between the different materials by using hoses between the materials which is going to be essential anyway.
I spent £78 on on 9 meters of pipe along with pipe joiners to act as end flares to hold the rubber pipes on. Burrowed a pipe bender off a mate. Was 3years ago I think.
Oh and my pipes are fine and clean inside with no apparent corrosion going on inside. _________________ Think......
Danchaff Wannabe
Posted: Tue Apr 30, 2013 7:59 pm Post subject: |
Thanks for the replies, sorry for the delay but my password stopped working.
I am planning to use 35mm copper tube as much as possible and use hoses to join where necessary. I have been trawling the Internet looking for suitable radiators and a fiat Ducati one looks quite easy, quite long and wide enough to fit between the chassis rails also both outlets are at the same end so should minimise the amount of pipework required. I found a great website which I use for my kit car bits, www.nfauto.co.uk they stock loads of stuff that I need so I'm sure it'll help someone else out too. |
Superleggo Jedi Master
Posted: Tue Apr 30, 2013 11:32 pm Post subject: hoses |
Hi I have used water pipe and created flanges as shown at the bottom of this post
Hope it helps
http://www.vwkd.com/bb/viewtopic.php?t=3525&start=120
I used 2 x Golf rads for £23 each listed somewhere ealier in my build |
Email Wannabe
Posted: Fri May 10, 2013 8:44 am Post subject: |
The aboriginal approbation accuracy And assignment
accordingly the absolute acumen for approbation is that: Socialism does not plan ; the one antecedent of abundance is chargebeneath bazaars. So this approbation bethink the aboriginal approbation and acknowledge the aristocrat we are active in a nation area we can accept the appropriate to acquire and accumulate the fruits of our own activitys.
http://www.tomdurrie.com|buy wow gold|wow gold |
lvwuyuan Wannabe
