mk2 digifant GTI into late bay crew cab
CharlieBus
PostPosted: Fri Jan 03, 2014 5:22 pm    Post subject: mk2 digifant GTI into late bay crew cab Reply with quote
Ive got all the bits waiting apart from the adaptor plate Grin
After having a measure up it seems the inlet manifold makes the engine to tall to fit the hole Has any one got any pics to prove otherwise help
Looking to keep the 15 deg angle with a Kennedy kit
If you listen carefully it sounds like a golf
trev
PostPosted: Sun Jan 05, 2014 11:23 pm    Post subject: Reply with quote
welcome charliebus Happy
look at my thread:
http://vwkd.co.uk/bb/viewtopic.php?t=3962&start=0&sid=09cb8b786b0438a014eded855db8fa29
it's a 1.9 diesel from a mk3 Golf/Vento but the block and head, cam cover etc are all similar to your petrol engine. Looking at photos of PB engines on google, the inlet manifold doesn't seem to be any taller than the 1Y inlet manifold that I have. It fits in well with about 3/4 of an inch of clearance over head. This is mounted at 15 degrees. I can't see it working at vertical at all...
CharlieBus
PostPosted: Thu Jan 09, 2014 12:34 pm    Post subject: Reply with quote
That's a fantastic help. Thanks very much. Really appreciate that.
We were looking at doing it at the 15 degree angle as we thought that is what was best. And how the adapter plate is set up!
Just going to check out your thread now! Be prepared for more questions and thanks again!
Grin
