Tomasz Padawan
Posted: Sun Sep 21, 2014 6:42 pm Post subject: Subaru conversion plate kit + MS2 PCB3 kit -Subaru pre-setup |
Hi All
I've decided to let go some of my project's parts.
The bits are as follow:
1. New Subaru conversion kit includung: - SOLD
- adapter plate, I pre-drilled 2 bottom holes for counter sunk bolts but they need to be drilled a bit more to accommodate bolts heads entirely and for fine finish,
- flywheel to take 200mm clutch,
- bolts&nuts including 2 counter sunk m10 bolts with 1.25 fine thread, they are 60mm long and 10.9 (hard). These are quite hard to find and with them installed there is no need to cut gearbox mounts.
SOLD
2. Megasquirt - MS2 with PCB3 kit including:
- MS2 PCB3 ECU, checked and tested, never used on a car, with MS
extra code uploaded and pre setup for a Subaru with 36-2-2-2
trigger wheel, wasted spark, standard ignitor,
- New JimStim 1.5, setup as well for 36-2-2-2 trigger wheel, with a
few jumpers,
- New 12' wiring harness,
- New, additional harness plug,
- Power supply/charger for JimStim,
- USB and DB9 cable to connect a laptop with MS2,
- New NB lambda sensor,
- New, Subaru 36-2-2-2 trigger wheel,
- New, 3 relays,
- New, fuse box (6 fuses),
- Used, Subaru 2.0L non turbo ignitor
Price £430 collected form SW Central London or £440 posted.
I've got the bits back home so allow a week/week and a half for pick up/delivery but can have it ready for Brighton Breeze.
Cheers[/b] _________________ Calm Bug |
