1.9tdi Into my Bay Window Jurgens '79.
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 12, 13, 14  Next
Wilfred
PostPosted: Mon Feb 23, 2015 12:50 pm    Post subject: Reply with quote
Slow done mate, or you will pass me! Nice progress. Did you get the tank out already to add fuel return?
skirk
PostPosted: Mon Feb 23, 2015 1:34 pm    Post subject: Reply with quote
Lol.
Yes tank is out ready for me to drill and add fuel return. Keep forgetting to check size of fitting required for the Passat fuel line.
skirk
PostPosted: Mon Mar 09, 2015 11:26 am    Post subject: Reply with quote
Engine bar/mount fabricated. Needs a rub down and repaint.
Hopefully have some pics later.
skirk
PostPosted: Wed Mar 11, 2015 2:46 pm    Post subject: Reply with quote
Here it is. Still needs repainting.
skirk
PostPosted: Sun Mar 15, 2015 2:03 pm    Post subject: Reply with quote
Engine on engine mount. One side needs raising an inch. Need to trim the bottom from the bell housing to give more clearance.
skirk
PostPosted: Sat Mar 21, 2015 4:15 am    Post subject: Reply with quote
I have succumbed and going to send the loom off to be altered.
Exhaust to think about next. Anyone have any photo's/plans etc of what bits and lengths required. ?
busbuddy
PostPosted: Sat Mar 21, 2015 5:35 pm    Post subject: Reply with quote
mine is on a 1Z, nice and simple
you are welcome to come and hear how quiet it is
Wilfred
PostPosted: Sun Mar 22, 2015 9:00 am    Post subject: Reply with quote
I really like your engine mount. It just looks good!
atschool
PostPosted: Sun Mar 22, 2015 9:52 am    Post subject: Reply with quote
that must make one hell of a noise to go from two big boxes to a single dinky single,still looks good lol
the weekends are never long enough
skirk
PostPosted: Sun Mar 22, 2015 10:21 am    Post subject: Reply with quote
Cheers. I will take you up on that offer. When are you around ?
busbuddy
PostPosted: Sun Mar 22, 2015 1:41 pm    Post subject: Reply with quote
not noisy at all, tdi's due to the turbo chewing up the resonance are not as noisy as petrol engines or other diesels.
if you hear any of the chavved up tdi cars with straight through exhausts that are normally followed by a black smokescreen its a different sound to a standard exhaust but its nothing like the noise of a big bore exhaust on a corsa or a straight through system on a diesel landrover
when I first finished the conversion i took the van for an mot with a similar length of exhaust pipe but with no silencer on it whatsoever, it sounded exactly like an old diesel railway shunter and the turbo whistle was louder than anything.
The mot man would have passed it on the sound but suggested that I fit a silencer of some sort just to make it resemble the original visually.
saon, i'm in evenings, sat mornings and most sundays
atschool
PostPosted: Sun Mar 22, 2015 6:26 pm    Post subject: Reply with quote
I stand corrected that's a bit of usefully information, it will make life a lot easier if I don't have to work out how to refit the big exhaust boxes
Page 7 of 14
