79 tdi doublecab
riggsi
PostPosted: Sat Jan 03, 2015 8:03 pm    Post subject: 79 tdi doublecab Reply with quote
This is my first post on here but I've been reading through through the build threads for a while and getting ideas.
I started rebuilding this 79 doublecab 2 years ago so it has been a bit of a longterm project that I have been working on between other projects.
When I started it was going to be fairly stock just slammed with an lawn mower engine until I had a spin in a tdi bay with a flipped audi box and decided to change direction a bit.
https://www.dropbox.com/s/m9e3yjq83qw3lg9/20150103_143635.jpg?dl=0
https://www.dropbox.com/s/nb33z3udpp178fz/20150103_143553.jpg?dl=0
https://www.dropbox.com/s/0n0uvodtou7zoap/20150103_143523.jpg?dl=0
riggsi
PostPosted: Sat Jan 03, 2015 8:20 pm    Post subject: Reply with quote
I started back on it a few weeks ago after after a break of 9 months and I am determined to get it on the road for summer.ive put an early front panel on it along with early front arches and I have plated the rear light openings and cut the out for a set of early tail lights.
It was completely rotten when I got it so I've replaced all outriggers and jacking points the complete rear floor (cab area) 2 front arches,cab floor sections both sides,front bumper bulge replaced with an early inner valance.
2 new rear corners,inner middle and outer cills on both sides and some rear arch sections.
I finally got around to pulling the engine out of my 99 passat 90 bhp last week and dropped it in to start planning the next step.
[url] https://www.dropbox.com/s/snuey7z233936ah/20150103_143542.jpg?dl=0[/url]
[url] https://www.dropbox.com/s/kbru73yr3o5fra3/20150103_143836.jpg?dl=0[/url]
Moominbus
PostPosted: Sun Jan 04, 2015 11:03 pm    Post subject: Reply with quote
Looks good! This will be one to watch, I can tell. You seem to have plenty of interesting projects to keep you busy in your workshop! Best of luck with it all and thanks for sharing.
riggsi
PostPosted: Tue Jan 06, 2015 9:24 pm    Post subject: Reply with quote
Cheers moominbus too many projects that's why this one has taken so long.
I picked up a corsa b eps unit at the weekend and got the linkages sorted between it and the passat steering column,I've bought a Bedford rascal steering rack on ebay yesterday so as soon as that arrives I can figure out the best location for the eps unit and make up a frame to mount it too.
Got started on my adapter plate too.
[url] https://www.dropbox.com/s/0of79qd7n52ybel/2015-01-06%2017.21.31.jpg?dl=0[/url]
[url] https://www.dropbox.com/s/vuh0e0y68tnmrz7/2015-01-06%2017.22.02.jpg?dl=0[/url]
[url] https://www.dropbox.com/s/yq94bscvt7ofqfx/2015-01-06%2017.22.46.jpg?dl=0[/url]
Wilfred
PostPosted: Fri Jan 09, 2015 9:08 am    Post subject: Reply with quote
Great work. Seems so much more easy to work on a crewcab!
Look at all room around the engine, the many angles from which you can look at it Laugh Out Loud
keep up the good work
PostPosted: Sun Jan 11, 2015 11:20 pm    Post subject: Reply with quote
Great work
Jacosmotor
PostPosted: Fri Apr 24, 2015 9:14 am    Post subject: Reply with quote
Hi riggsi just found your thread wondering if you got any further as I have a 70 crew cab would like to do same when funds allow
riggsi
PostPosted: Wed May 06, 2015 6:17 pm    Post subject: Reply with quote
Haven't got anything done in a couple of months I've been busy with other projects but I did pick up a 130 bhp passat doner and a set of air bags and air shocks so I am hoping to get back to it in a few weeks.
What condition is your crew cab in?
