justin pane Force Sensitive
Joined: 14 May 2008 Posts: 19 Location: SOLIHULL W. MIDS
Posted: Mon Mar 23, 2015 7:46 pm Post subject: Advice on fitting a 2lt 6 rib box with a 0.7 fourth |
I have a 2lt 6 rib box with a 0.70 4th (DK converted to fit a bay) and would like advice on fitting it in my 72 bay window which is fitted with a 2.1lt oxyboxer, would 0.70 4th be too tall for the engine ? or would it be better to fit a 2lt DK box with 0.82 4th which I have also. which box do I go with?
thanks for any advice. |
Wilfred Darth Admin
Posted: Tue Mar 24, 2015 8:38 am Post subject: |
I would go with the longest 4th gear. It is always nice to have a bit longer legs. on top of this, it is just fourth gear. The engine has to work harder pulling up than keeping it up to speed. So a longer fourth would be less demanding for the engine compared to a longer 1st.
In my opinion, it is not to much effort to swap boxes so you could just test them both? _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
Posted: Wed Mar 25, 2015 7:30 pm Post subject: Gearbox change |
| Thanks for the reply, I'll do as you suggest, and as you point out its not such a big deal to swap boxes if the engine can't cope. cheers |
tracktony Initiate Jedi
Posted: Wed Sep 23, 2015 4:08 pm Post subject: Re: Gearbox change |
| justin pane wrote: | | Thanks for the reply, I'll do as you suggest, and as you point out its not such a big deal to swap boxes if the engine can't cope. cheers |
hi have you still got both of these boxes if o do you want to sell one thx tony |
Posted: Sun Oct 04, 2015 4:40 pm Post subject: Re: Gearbox change |
| tracktony wrote: | | justin pane wrote: | | Thanks for the reply, I'll do as you suggest, and as you point out its not such a big deal to swap boxes if the engine can't cope. cheers |
ony |
Hi Tony sorry for the delayed reply, done a couple of trips with the 0.70 box
so far and I'm thinking of sticking with it, one more trip in a couple of weeks
and I'll decide which one.
where abouts are you?
regards JP |
Posted: Wed Oct 14, 2015 8:20 pm Post subject: Re: Gearbox change |
| justin pane wrote: | | tracktony wrote: | | justin pane wrote: | | Thanks for the reply, I'll do as you suggest, and as you point out its not such a big deal to swap boxes if the engine can't cope. cheers |
ony |
regards JP |
Welshpool mid Wales so only about an hour from you |
