4x4 bay conversion
Goto page Previous  1, 2, 3
roverv8bay
PostPosted: Thu Dec 08, 2016 11:28 am    Post subject: front suspension lift Reply with quote
G'day all. Now for front end update. I fitted the adjusters onto the beam but in the wrong location to give max lift. After some deep thought & finding front coil overs & rear shocks of a new Ford Ranger at the local tip recycling shop for $40.00 the lot I started setting up the setup required to mount the coilovers to the lower shock mounts After 1st setup a well respected VW GURU questioned the load strength on the lower stud. after a few attempts & sheets of a4 paper this is the result.
I had to cut the plates with a cut off disc on the 4inch grinder. due to plasma cutter needing new tip.
how the shocks are shaped with steel rod at the bottom to clear the driveshaft's on the Ford so perfect clearance on the kombi.
this is with the adjusters all the way down
after the coils were fitted
trev
PostPosted: Mon Dec 12, 2016 7:28 pm    Post subject: Reply with quote
this is awesome stuff!!
Wilfred
PostPosted: Tue Dec 13, 2016 10:01 am    Post subject: Reply with quote
Indeed it is! keep up the good work (and keep us posted!)
roverv8bay
PostPosted: Sat Dec 17, 2016 10:49 am    Post subject: Reply with quote
started the instrument cluster. It will be recessed into the frame 25mm with Perspex cover. I have to but the speedo yet it has to be electronic to work with the Toyota drive I have to move the tacho to where the volt meter is
Wilfred
PostPosted: Fri Dec 23, 2016 5:55 am    Post subject: Reply with quote
Fancy Gauges!!
wouldn't you be easier off using a GPS speedo?
There are nice ones available on the big internet. give it 2 wires, for 12v feed and you are set and done!
Got one myself for a Jaguar, which I upgraded with a modern motor and trans, which meant I lost the old cable drive.
roverv8bay
PostPosted: Fri Dec 23, 2016 7:07 am    Post subject: Reply with quote
G'day Wilfred. Here in Australia we have issues with Govt over the GPS type speedo's.
Wilfred
PostPosted: Tue Dec 27, 2016 11:23 am    Post subject: Reply with quote
Shame. in the Netherlands they are fine with it. If you can tell the speed, it doesn't matter how you do it.
Page 3 of 3
