Wiring Loom conversion
pkrboo
PostPosted: Thu Apr 06, 2017 5:20 pm    Post subject: Wiring Loom conversion Reply with quote
I have an engine and loom out of a 1998 Forester. It is the one with the ECU attached to the engine itself. The way i see it it should be easier to sort.
However, it seems impossible to find any wiring diagrams for it.
Does anyone have a wiring diagram for an X6 ECU that bots to the engine?
PostPosted: Sat Apr 15, 2017 10:13 pm    Post subject: Reply with quote
In my limited experience.....
You are far better off searching for the subaru service manual for the donor vehicle rather then a wiring diagram for a specific ECU code.
I've found the Impreza turbos subaru service manuals on PDF for both classic and facelift models which neither ever specified the ECU code. Even then I found the best source for rewiring the ECU was in EFI trouble shooting area of the manuals and not the electrical wiring diagrams.
PostPosted: Sun Apr 16, 2017 7:09 am    Post subject: Reply with quote
http://jdmfsm.info/Auto/Japan/Subaru/Forester/1998/Service%20Manual/DIAGNOSTICS%20SECTION.pdf
Page 50
Sorry just realised these are US specs.
Came from this site.
Will keep searching.
pkrboo
PostPosted: Wed Apr 19, 2017 6:57 am    Post subject: Reply with quote
Cheers Kai, those links are for the multiplug ECU this one has a single B84 38 pin conenctor or so.
i'll keep searching too and keep guessing while i cut wires!!!
PostPosted: Sun Apr 23, 2017 8:03 am    Post subject: Reply with quote
I'm open to being corrected as I'm by no means an expert, but to my knowledge all subaru have the ECU placed in the left hand side footwell and are not attached to the engine. Also the phase 2 ECU's are all three plug units.
pkrboo
PostPosted: Mon Apr 24, 2017 7:07 am    Post subject: Reply with quote
no, there were some with the ECU on the Engine, 2 plugs on it, one plug to the car and one plug to the engine sensors. ill see if i can do a pic
