Golf gti into 71 bay.
megabus
PostPosted: Wed Sep 06, 2017 8:58 pm    Post subject: Golf gti into 71 bay. Reply with quote
When I fit the golf engine with alternator ,do I need the camper voltage regulator as fitted to the 71 loom.As I'm fitting a new loom to the camper and want to keep it as simple as poss.If I do need the voltage regulator how will it connect to the new stuff .Thanks .
Wilfred
PostPosted: Thu Sep 07, 2017 10:19 am    Post subject: Reply with quote
The GTI most likely has an integrated voltage regulator. so you don't need the original regulater.
Jus connect the big wire from the alternator to your battery. that's it.
The alternator also needs a 12v feed, but that is most likely integrated in the GTI loom. If this feed is lacking, the alternator will turn but not start charging.
Check by measuring the voltage when the engine runs. Should be around 14V.
megabus
PostPosted: Sat Sep 09, 2017 9:29 am    Post subject: gti into 71 bus Reply with quote
next problem is ecu,how to get around immobiliser,is there a different one I could use or is the only way to have it removed.I didn't get the little black box off the donor car oops,so can't use it. thanks Ian
Wilfred
PostPosted: Sun Sep 10, 2017 10:00 pm    Post subject: Reply with quote
I would just have it removed. Just 50 euro over here, so 40 britisch pound?
megabus
PostPosted: Sun Sep 24, 2017 5:27 pm    Post subject: How can I get around the tranny speed sensor problem Reply with quote
Not sure if my 95 gti mk3 agg engined golf donor car had sensor,I think it did.Because something is stopping it starting and I believe that it won't start without it connected.What can I do to get it running,any help much appreciated.cheers Ian
PostPosted: Fri Sep 29, 2017 1:05 pm    Post subject: Reply with quote
If you haven't the immobiliser items then buy this.
https://www.ebay.co.uk/i/272860766126
Or contact that guy Bartek on eBay and get him to de-immobilise you current ECU.
If you look up AFN tuning ECU something like that you'll find the guy. He's based in redhill surrey.
illzlee
PostPosted: Mon Nov 20, 2017 1:49 pm    Post subject: Reply with quote
You can buy a defeat chip:
https://www.ebay.co.uk/itm/VW-Golf-MK3-MK4-GTI-VR6-DIY-Immobiliser-Defeat-T4-Passat-Beetle-Fast-Dispatch/151754209523?fits=Model%3AGolf%7CPlat_Gen%3AMK+III&hash=item23554178f3:g:71IAAOSwDuJW1FhX
There are cheaper versions of this too - think the one I got for the AGG I'm fitting cost about £7 posted on the slow boat from china
'79 Bay running citroen 1.9td and phat tyres!
