Replacing Rear wheel bearing seals
PostPosted: Fri Jul 06, 2012 11:02 am    Post subject: Replacing Rear wheel bearing seals Reply with quote
Hi All!
I currently have the back end of my van in pieces and I thought While im here it would be nice to flush my rear wheel bearings out and replace the seals.
The bearings them self feel good so I don't wanna replace em or damage them. But my Question is.....
How do get the rear axle out? Is it just a matter of drifting it our with a hammer or is there a hidden circlip I need to undo?
I've tried to lightly drift them out, but nothing seems to be happening so i thought I would check with you guys first!
Thanks for any help/advice in advance!
Alex
PostPosted: Fri Jul 06, 2012 8:17 pm    Post subject: Reply with quote
Swing axle or IRS?
If its IRS, I imagine it is, I've always undone the cv joint bolts, oh and the hub nut and then the stub axle should pull through. possibly with some use of the "Persuader"
If that's no good you can always drill a small hole into the old seal and pull it out with what ever you can get in there.
PostPosted: Sat Jul 07, 2012 10:14 am    Post subject: Reply with quote
Yes sorry its a 1972 bay window with IRS.
Alex
Superleggo
PostPosted: Sat Jul 07, 2012 11:48 pm    Post subject: Reply with quote
I gave mine a good thump with a copper hamer fter undoing the nut and it poped out on the second hit. I removed the drive shafts first.
It seems t ohave gone back together without a problem
PostPosted: Fri Jul 13, 2012 4:49 pm    Post subject: Reply with quote
Cheers chaps!
Mine dont seem to wanna move so Im gonna try and press em out if that doesnt work then they will just have to stay in lol! The bearings are fine i Just wanted to clean up the hub carriers and re greese everything.
PostPosted: Sun Jul 15, 2012 10:43 pm    Post subject: Reply with quote
Hi Mate - there is no circlip you just need to beat em out.....sledge hammer works Grin Make sure you put the nut on when you hammer it though as you will f up the thread. Nuts are only a few quid from GSF so much easier to replace them!
PostPosted: Fri Aug 03, 2012 12:21 pm    Post subject: Reply with quote
haha nice one chap! Clearly I havent been beeting them enough lol! Bit worried about damaging the wheel beerings but might just have to sacrifice them in the beating and get some new ones. Cheers
Singerlovelife
PostPosted: Tue May 21, 2013 9:34 am    Post subject: Reply with quote
buy runescape gold
buy wow accounts
sell wow accounts
cheap wow accounts
cheap d3 gold
buy diablo 3 gold
JohnJohnson
PostPosted: Wed Oct 10, 2018 8:06 pm    Post subject: Re: Replacing Rear wheel bearing seals Reply with quote
Alex (FTS) wrote:
Hi All!
Alex
hey
I've constantly fixed the cv joint fasteners, goodness and the center point nut and after that the stub pivot should pull through.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
