Gear linkage
Goto page Previous  1, 2
splitbusvanatic
PostPosted: Thu Feb 26, 2015 4:43 pm    Post subject: Reply with quote
its ok. Found it. Thanks..
trev
PostPosted: Thu Feb 26, 2015 11:43 pm    Post subject: Reply with quote
hi dan Happy
here 'tis:
http://forums.tdiclub.com/showthread.php?t=279543
trev
PostPosted: Thu Feb 26, 2015 11:46 pm    Post subject: Reply with quote
duh, didn't see there was a page #2!!
rabbitboy
PostPosted: Sat Mar 07, 2015 4:04 pm    Post subject: Reply with quote
Boxster cable shift working fine on my bay and very simple to fit. The cables are pretty flexible too and can be bent to clear things.
skirk
PostPosted: Thu Mar 12, 2015 12:43 pm    Post subject: Reply with quote
trev wrote:
has nobody thought to mount the cable shifter base under the cab floor with just the gear stick poking up through, like the stock shifter?
This is what I thought. Try to keep as stock as possible in looks.
Wilfred
PostPosted: Sun Mar 22, 2015 2:13 pm    Post subject: Reply with quote
I finally took some pics of my setup.
See also this thread: http://vwkd.com/bb/viewtopic.php?p=31784#31784
i can select all 6 positions now, using original gear lever .5 forward, 1 reverse.
Note: I don't know how the shifting pattern turned out yet, as I havent driven it like this. But in case it turns out wrong, I have ideas on how to change that. But that will have to wait for now.
valentind06
PostPosted: Tue Dec 18, 2018 4:24 am    Post subject: Reply with quote
Wilfred wrote:
Hello,
yes, I used a double joint and that works well. One problem I encounterd is the lengt of the shift. You need to adjust the floorplate of the gear selector to increase the length it can move cause otherwise it is just not enough for the passat box.
I really prefer the rod linkage option over cables Self Stockage. I have never seen a cable setup I really like, as in most cases you would loose the walkthrough.
I desperately want to work on the bus again and than I can show some pics.
But there are also ready-made joints that you can install without problems, you know.
Wilfred
PostPosted: Thu Dec 20, 2018 1:26 pm    Post subject: Reply with quote
I did not now that. Can you show me?
oh, and it is so much more rewarding to make stuff yourself!
Page 2 of 2
