busbuddy Force Sensitive
Posted: Tue Jan 02, 2007 9:54 pm Post subject: citroen to vw adapter SOLD |
brand new off phil, never fitted
since ordering the adapter I bought a td t25 karmann cheetah in germany and my bay is promised to a mate who don't wanna diesel motor so the kit is for sale. No idea what the difference between the peugeot and citroen flywheels are so I don't know if you can fit it on a pug
I also have a xantia 1.9td engine that was gonna be my spare, it had only done 80k with full history but has sat in my shed since june, the pump needs changing for a full mechanical one.
Can't guarantee the engine but it's free if you can pick it up
fbiiburton Force Sensitive
Posted: Tue Jan 02, 2007 10:36 pm Post subject: |
| How much you asking pal? |
Posted: Tue Jan 02, 2007 10:49 pm Post subject: |
sorry, had to nip off and try to find the original price coz I've forgotten :smt042
190 should do it |
famous phil Jedi Guardian
Posted: Tue Jan 02, 2007 11:27 pm Post subject: |
peugeot and citroen ( PSA GROUP ) flywheels the same on most diesels and will fit 1.9 petrol's ,,, I ALSO THINK THAT THE ENGINEER PUT AN EXTRA BRACKET IN THE KIT so you will have one chanel milled to fit rear engine mount
one plate with angle welded on offside mount
+ one angle about 8" with three holes in , this is the one thats for the t25 , fits the engine cradle ,
+adapter plate
and flywheel with centre bearing
your kit will fit splity, bays n t25 , or like scrapheap chalenge a beetle any other with that type of box realy
what year is xantia , if not HDI then its just the antitheft device that needs taking off , and then fit the old solernoid ( magnetic ) fuel cutout unit
one day you might wished you fitted it to your cheetar even if your thinking of fitting a vw tdi 'lol'
 _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
Posted: Wed Jan 03, 2007 6:18 pm Post subject: |
| famous phil wrote: |
one day you might wished you fitted it to your cheetar even if your thinking of fitting a vw tdi 'lol' |
true, but I've got your number
The conversion in the bay was only for mpg anyway and the cheetah is giving 40mpg at the moment so thats good enough for me, I've got the racecar for speed if I feel the need.
Both xantia motors were of 1994 vintage, one had the bosch pump and ecu to control it, the other had been heavily modified by a wealthy chav which I sold to buy the cheetah |
Posted: Wed Jan 03, 2007 7:47 pm Post subject: |
the xantia fuel pump , that you have , i could get it going on the floor , in two hours , using just three wires
the antitheft shield needs removing to take off the ECU , then fit the old type shut off unit , when you take the shield off there is a 2mm roll pin you need to knock this out , if not you can snap the aloy housing round the fuel adjusting screw 'like i did on one , a right angle drill would be handy , and easy out ,, or good old small sharp chisel
to remove the snap bolts
but you could use a pump off a 405 1.9 td ,  |
Posted: Wed Jan 03, 2007 8:28 pm Post subject: |
yeah I was gonna use the pump off a pug coz the citroen ecu controlled the fast idle, injection timing, egr and glow plugs and most of these would have to be adapted to the wiring in the van. There was no 'easy' way to chop into the harness for all the sensors and ecu.
It was gonna be easy to swap my semi-electronic pump for a mechanical one on the peugeot/citroen forum anyway.  |
Posted: Wed Jan 03, 2007 8:31 pm Post subject: |
the antitheft shield needs removing to take off the ECU |
the ecu is a proper ecu about the size of a video which is mounted on the wing |
Posted: Wed Jan 03, 2007 9:18 pm Post subject: |
YOU SURE ITS A 94 AND NOT A 97 , i've done ones from peugeot 406's before to fit into t25's , and have been ok to do , + i had a 1995 xantia many years ago and it was not like the one you mention , MIGHT HAVE HAD LUCAS pump and egr |
Posted: Wed Jan 03, 2007 9:29 pm Post subject: |
I bought a manual for it and did all my research to get a non leccy engine so you can imagine my shock when I got the car, after some panic postings on the pug/citroen forum they just said all the manuals and dates are crap.
I broke the car on e-bay and that was hilarious, the seat belt tensioner controller box was under the centre console which took me a day to find and it only got worse.
sorry, the car was a '96, my daughter was born in '94
over on the far left you can just see the grey connector going into the ecu |
Posted: Thu Jan 04, 2007 12:42 am Post subject: |
bit of a change over year pump still looks likle one ive done before , dont need wires on the throtle spindle , does it have wires going to two efv's on the lower part of the pump , ive ran one with these off to , dont get as much fuel boost for when turbo kicks in
sodd it will work just as well with the old 405 pump M8 |
den Padawan
Posted: Thu Jan 04, 2007 1:36 pm Post subject: |
Hi Is the adapter / kit still for sale ? If so what is in the kit and could you give me your post code.
Thanks Dennis
Can't guarantee the engine but it's free if you can pick it up |
