Posted: Mon Feb 06, 2006 5:01 pm Post subject: GBE - Conversion Plates for Ford, VW, Citreon/Pug & Vaux |
Thanks To Alex for this one.
I got my engine conversion plate from CBE Tel: 01270 841 081. They do conversion plates for Ford, Vw, Citroen/Peugeot and Vauxhall all to fit old skool vw. The kit costs about £250 and takes a week or so for them to machine it for ya.
Summut from another website.....
If you are fed up with the VW beetle engine and want to a change you will need an adaptor plate to match the gearbox to the engine. The choice of engines wide and varied e.g. Ford / Subaru / Renault / Alfa etc.
The adaptor plates are available from :-
GB Engineering ltd
Westfield
Wybunbury road
Walgherton
Nantwich
Cheshire
CW5 7NG
phone 01270 841081
They cost around £250 and normally consist of an aluminum adaptor plate, replacement drive shaft, bolts/studs. Cos the plate is aluminum it is advised you fit helicoil inserts to prevent the threads stripping when you bolt up the engine. You will then need to sort out a cooling system by fitting radiators etc. It does mean you can fit a decent heater. It is also wise to fit beefed up gearbox mounts as the heaver engine with greater torque will put a lot of strain on the original mounts - mine ripped off the front mount from the chassis. _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Posted: Thu Feb 09, 2006 4:40 pm Post subject: |
Apparently don't do them anymore
But keep trying them they might change their mind
jerry79 Initiate Jedi
Posted: Tue Jun 27, 2006 7:12 pm Post subject: adaptor plates |
| or like ive done, its qutie simple really take the bell housing of the engine your going to convert to and the vw bellhousing down to your local tool maker / precision engineer tell them how much distance you want in between the two and if they are any good hey presto. you should be able to fit nearly any motor to your box you choose. see........ the possibilitys are endless! the sme applies to the fly wheel mine got a 32mm spacer from the crank the bell housing is 32mm thick ive still got a 210mm vw clutch flywheel and starter motor. |
Covin Darth Admin
Posted: Tue Jun 27, 2006 9:25 pm Post subject: Re: adaptor plates |
| jerry79 wrote: | | or like ive done, its qutie simple really take the bell housing of the engine your going to convert to and the vw bellhousing down to your local tool maker / precision engineer tell them how much distance you want in between the two and if they are any good hey presto. you should be able to fit nearly any motor to your box you choose. see........ the possibilitys are endless! the sme applies to the fly wheel mine got a 32mm spacer from the crank the bell housing is 32mm thick ive still got a 210mm vw clutch flywheel and starter motor. |
What sort of costs were incured for the work jerry ? Bet it wasn't to bad.
Love to hear more and see some pictures if you have any. _________________ DARREN
I LOVE RUST ME
Posted: Wed Jun 28, 2006 7:57 pm Post subject: billet bell housing |
well 50 quid gets you a big enough lump of ally billit, and about 150 gets the job done on the cnc machine, it only took about 50mins to make but about 3hrs to sort the design and create the program. i made a working prototype from steel first to make sure the motor would fit and run with the gearbox properly which was not pretty but it seemed to work. having had the billit one made it looks cool when you can see it but is machined to a perfect fit so all in all about 4-450 all done with a flywheel spacer and kennedy clutch kit,
nuts and bolts.
its the most expensive part of my conversion but no one makes a adaptor plate to fit my engine so i had to get one made, and i did. |
famous phil Jedi Guardian
Posted: Thu Oct 12, 2006 10:45 pm Post subject: Conversion Plates for Citreon/Pug to vw |
| jp wrote: | Thanks To Alex for this one.
GB Engineering ltd
Westfield
Wybunbury road
Walgherton
Nantwich
Cheshire
CW5 7NG
phone 01270 841081 |
Do'nt think they did any peugeot adapters
famous phil peugeot citroen engine adapter kits to fit volkswagen flat four boxer gearbox 07703844035 home 01325401867 email caroline.smith380@ntlworld.com best to phone after 6pm , _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
